Possible fix!!!
POSSIBLE FIX!
My wife and I have identical phones, bought from same carrier few days apart, 85% apps are the same, and after update her phone is doing great, but mine is eating battery like mad: almost 2% an hour sitting idle, battery could not last 10 hours on pretty normal use. Restarted randomly a few times. Before upgrade my phone lasted 24 hours easily.
Tried everything I could find: wipe cache, reset app preferences, set a high performance mode without optimization, even did a factory reset. Nothing.
Flashed official firmware from Sammobile, but only the AP part. I know that back in my Note3 days, the AP was only thing I needed. What a mistake. After that I lost vibration and got some double tabs in “settings”. The phone did not lag, but it wasnt doing good either, and the battery was horrible. Lost 15 percent overnight on idle.
I then reverted to official 6.0.1., and after that I flashed 7.0 again, but this time I flashed everything that was in the archive from Sammobile:the BC, AP, CSC and something else, cannot remember what it was .
What a difference!
The phone went back to normal, the OS is smooth, and the best part: lost only 4 percent of battery overnight!
So, looks like this is the way to go. If you are unwilling to do the full reset, things have changed since older Samsung phones.
How I did it:
Thru Samsung cloud. You can backup everything you want: I moved my pictures and any other large files to SD card, and let the phone backup. It will backup everything except your app data: homescreen layout, alarms, contacts, calendar (if you already do not have it on Google).
The whole process lasted no more than an hour from start to finish with backup, flashing and restoring. Could not recommend more!
75% battery from 3PM yesterday lasted until 10 AM this morning.
So far so good.
