1. AC Question's Avatar
    I just updated my Galaxy s7 and notice in the drop down menue I no longer have the option of UBS which I use when I'm out for long periods of time at work or away from a charger where I may still need to conact someone it is literally life saving. is there some way I can get this option back?
    03-30-2017 11:30 AM
  2. Tim1954's Avatar
    You go to device maintenance app and do it from there. You can add this app as a shortcut to your home screen if you wish.
    03-30-2017 08:53 PM
  3. LineKill's Avatar
    Pull down from the top twice. Tap on the words Power Saving, make sure you tap on the words. From there just tap on Max.
    If you do not see Power Saving on that screen, scroll to the next screen(s) to the right.
    03-30-2017 10:40 PM
  1. March Security Update Missed
    By Go0gle in forum Google Pixel & Pixel XL
    Last Post: 05-03-2017, 09:36 AM
  2. My phone is not getting marshmallow update
    Last Post: 03-30-2017, 08:38 PM
  3. Gboard\swiftkey battery useage
    By gerrya in forum LG G4
    Last Post: 03-30-2017, 10:56 AM
  4. Replies: 0
    Last Post: 03-30-2017, 10:00 AM
  5. why the system update of my phone is taking time
    Last Post: 03-30-2017, 09:52 AM
