1. AC Question's Avatar
    Over the past 4 months, my data usage has gone up and that "Android OS" has been using a lot of background data. What exactly is it using it for and how do I stop it? My data connection often switches from LTE to 4G which then becomes very slow or unusable. This can happen in places where I normally get a great connection too. Restarting my phone or switching data on/off often solves this problem, although it has become very tedious to do. I am really fed up with these issues. I am from Hawaii and few people here suggested me TCAWireless as the best place to solve any Samsung related issues. f anyone has any idea of how to solve these problems please guide me! I am willing to try out anything suggested.
    04-13-2017 05:57 AM
  2. Tobym1982's Avatar
    Is ur phone rooted? Main thing with these phones is that fhey ask alot of permission and overlays and others but if u have developers optins enabled then u should check in there to see if any areas r checked that aint supposed to be
    04-13-2017 07:37 AM
  3. LineKill's Avatar
    If you go into data usage in your settings you will be able to find out what is using so much data.
    04-13-2017 09:02 AM
  1. Replies: 2
    Last Post: 04-16-2017, 02:52 PM
  2. LG G6 Help
    By JAG21979 in forum LG G6
    Last Post: 04-14-2017, 09:41 AM
  3. Replies: 0
    Last Post: 04-13-2017, 05:06 AM
  4. Replies: 1
    Last Post: 04-13-2017, 04:48 AM
  5. for pc problem
    Last Post: 04-13-2017, 04:40 AM
