1. AC Question's Avatar
    I have tried installing various call recorder apps on my s7 phone but none of them is recording the incoming voice. It only records the outgoing voice.
    05-05-2017 04:10 AM
  2. LineKill's Avatar
    Try this one, it will record both sides of the conversation for you.
    https://play.google.com/store/apps/d...id=com.nll.acr
    divyansh bairagi likes this.
    05-05-2017 04:33 AM
  3. 1812dave's Avatar
    Try ACR from m@nllapps
    05-05-2017 08:51 AM
  4. rayzor_uk's Avatar
    total recall for me tried them all
    05-07-2017 03:42 AM
  5. shuklaharshit75's Avatar
    Audio of auto Call recorder is single sided. There is no sound for the other side, apps are only recording what I speak on my mobile. I've tried 4-5 apps giving them all permissions, Battery optimization ignored and everything but Auto call recording apps aren't working.
    08-27-2017 01:18 AM
  6. divyansh bairagi's Avatar
    This is really helpful for me. I mean ACR.
    09-22-2017 07:57 AM
  7. Terry Hensley's Avatar
    ACR works like a champ on my Galaxy S9 Plus, records both incoming and outgoing voices. I wish I'd known about this app two days ago when dispatch called. This is the best tool to have when someone says I never said that.
    07-23-2018 03:00 PM
  8. Moz35's Avatar
    I am having the same issue with my Motorola one. Did you find out any solution?
    12-29-2018 01:40 AM
  9. mongler's Avatar
    I have had this problem as well. I assume its related to updates of either the app or the OS that do not inform you that numerous opaque permissions settings have been changed.
    These things happen increasingly often with apps like this (for perspective: these apps are completely against the rules on iPhones... since its illegal to record someone else on the other line in most states in the US and I am sure plenty of countries outside of the US), both by the nature of the application and also by the nature of the debate about privacy.
    Notably, recently, some of these apps can no longer display the contact information of the caller in question. Only the number. It does not matter what permissions you enable for the device.
    in my case, I did not notice that the app's settings (more than just permissions) had changed and I missed several days of records after an update.
    Its incredibly annoying because, of course, you would never know that something had happened UNTIL YOU NEEDED the record, just as you never know that whatever tool/device you need to function is broken until you actually need it.
    I can't blame them. I also don't want the application to constantly remind me to check the settings.
    Its a reminder of just how much functionality we depend on these devices. I rarely audit my desktop computer's software/settings as often as my phone and depend on it for critical functionality far less.
    04-12-2019 02:55 PM
  1. photos and videos not sgowing in gallery!!
    By joseph jassen in forum More Huawei Phones
    Last Post: 05-24-2017, 12:22 AM
  2. Replies: 1
    Last Post: 05-05-2017, 03:12 AM
  3. How can I enable Voice Assistant (TalkBack) using Google Now or S Voice?
    By DarkMist12 in forum Samsung Galaxy S7 edge
    Last Post: 05-05-2017, 02:21 AM
  4. Why does my screen not rotate and heart rate sensor not work?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 05-05-2017, 02:20 AM
