1. AC Question's Avatar
    I used to charge my S7 overnight, even though I always had 30-40% battery left at the end of approx 18hrs. Since the update was installed, my battery is dead within 12-14hrs. Also my phone keeps telling me to 'optimize my Apps' to save battery life: Why, it was never a problem before the update?
    I use my Samsung for work and need certain Apps (especially e-mail) open all the time. Now I have to close them down or carry a mobile charger with me everywhere.
    As far as I'm concerned, this update has achieved only one thing; it makes me want to throw my Samsung in the bin and buy an Iphone!
    06-26-2017 05:08 AM
  2. DOGE THE NICE DOG's Avatar
    Is it on performance mode?
    06-26-2017 07:54 AM
  3. Ca_lvn's Avatar
    Restart your phone most likely it will calm down to normal also run system maintenance to optimize battery
    06-26-2017 10:43 AM
  4. CWinkler's Avatar
    It also seems like it takes the phone several days to "learn" usage patterns and optimize itself. Like others have suggested, run device maintenance and maybe even do a cache wipe. Restart your phone. And give it some time to sort itself out.
    06-27-2017 05:41 AM
  5. tedbearclaw's Avatar
    I have not done any recent updates and I myself have noticed horrible battery life the past few weeks. I unplug my phone at 430 am. Sick it in my pocket when I leave for work all apps killed and nothing in use at all, by 830 I will already be down to almost 70%. With no screen usage. I have optimized my phone and have completed several power cycled and cleared cache.
    06-27-2017 06:23 PM
  6. CWinkler's Avatar
    Maybe you got my old returned phone (just kidding, unless you're with US Cellular in which case you might have). If you haven't yet installed GSam battery monitor app, I'd recommend it. Will give you more information to see what might be causing the drain. You also need to connect your phone to PC and run some commands to enable more data within that app.
    06-27-2017 06:30 PM
  1. My Doogee x5 gone CRAZY! pls help!
    By TheMegaSheep in forum General Help and How To
    Last Post: 06-27-2017, 03:48 AM
  2. Replies: 1
    Last Post: 06-26-2017, 12:08 PM
  3. Replies: 1
    Last Post: 06-26-2017, 07:37 AM
  4. Why can't I sync my Facebook/Messenger contacts to my phone?
    By ruiDiogo in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-26-2017, 06:15 AM
  5. Replies: 0
    Last Post: 06-26-2017, 04:17 AM
