I have an SM-G930P from Sprint and I had problems with it because it would turn on until the sprint logo appeared and then the phone would just turn off on it's own. When it turned off I noticed that it would have a blue light on the top left right next to the Samsung logo.
I then put the Nougat 7.0 firmware (SM-G930P_G930PVPS4BQE1) using Odin. Odin said that it passed but the phone just shut off on me again instead of taking me to the phone setup process.
The phone now only turns on if the charger or the usb is connected.
Ive tried to wipe the cache and doing a factory reset but it hasent worked.
This is what happens
It says "Recovery Booting" which is normal
Then it transitions to this:
And then to this:
The phone turns off after it reaches 22-30%
And then to this:
