1. umbreonsenpai's Avatar
    I have an SM-G930P from Sprint and I had problems with it because it would turn on until the sprint logo appeared and then the phone would just turn off on it's own. When it turned off I noticed that it would have a blue light on the top left right next to the Samsung logo.
    I then put the Nougat 7.0 firmware (SM-G930P_G930PVPS4BQE1) using Odin. Odin said that it passed but the phone just shut off on me again instead of taking me to the phone setup process.
    The phone now only turns on if the charger or the usb is connected.
    Ive tried to wipe the cache and doing a factory reset but it hasent worked.
    This is what happens
    It says "Recovery Booting" which is normal
    Then it transitions to this:
    And then to this:
    The phone turns off after it reaches 22-30%
    07-22-2017 09:39 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Have you installed the latest Samsung drivers to your PC?
    07-22-2017 09:57 AM
  3. umbreonsenpai's Avatar
    I just updated it right now. Should I try flashing with Odin again?
    07-22-2017 10:09 AM
  4. umbreonsenpai's Avatar
    07-22-2017 10:10 AM
  5. Golfdriver97's Avatar
    Yes, but which version of Odin are you trying to use?
    07-22-2017 10:10 AM
  6. umbreonsenpai's Avatar
    3.11.1
    07-22-2017 10:11 AM
  7. umbreonsenpai's Avatar
    I tried flashing it after I upgraded but it still dosent work.
    07-22-2017 02:43 PM
  8. Golfdriver97's Avatar
    Sorry for the delay...try redownloading the file, change cables and USB ports.
    07-22-2017 05:08 PM
  9. Madecky Uchozun's Avatar
    These devices have a Lithium batteries, that show the charge not objectively. You should take into your mind. And if you have 30-35%, you need to charge your device
    07-26-2017 11:09 PM
  1. Is there any roms out for my phone Samsung Galaxy J3 Emerge SM-J327P?
    By Michael Robinson8 in forum Samsung Galaxy J Series
    Last Post: 12-20-2018, 06:11 PM
  2. My Note 5 has storage issues
    Last Post: 07-22-2017, 12:17 PM
  3. Replies: 1
    Last Post: 07-22-2017, 11:40 AM
  4. Phone won't lock
    By Andrew Rokey in forum HTC U11
    Last Post: 07-22-2017, 11:33 AM
  5. Why does my tablet hang up when caling?
    By guardian1945 in forum Ask a Question
    Last Post: 07-22-2017, 08:46 AM
