1. AC Question's Avatar
    I had 15% the night before and went dead after one text message in the morning.
    07-31-2017 11:47 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you mean it didn't charge overnight? Are you sure it was positioned correctly, and that the wireless charger didn't become unplugged at some point?
    07-31-2017 01:08 PM
  3. CWinkler's Avatar
    Did you notice if the wireless charger had a blinking LED? I've had that happen a couple times, and when it does it isn't charging the phone. You need to remove the phone, let the charger go dark to reset, and then put the phone back on and check for solid LED. Then you can check to make sure the phone is charging.
    B. Diddy likes this.
    08-01-2017 05:57 AM
  4. Tim1954's Avatar
    Yes, under certain circumstances, they can actually discharge the battery...
    08-01-2017 06:01 AM
  5. Koalalala's Avatar
    You may check whether the wireless charging has been connected to the power well or charge it in a horizontal way.
    08-18-2017 04:39 AM
  6. SexyLi's Avatar
    Remove your phone case and you can change several positives to try it. Sometimes it may connect well.
    08-18-2017 04:44 AM
  1. What is the floating butterfly
    Last Post: 08-13-2017, 07:41 PM
  2. Casting to devices "reboots" my WiFi after Nougat update on Galaxy Tab?
    By marriedgeek in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 07-31-2017, 01:12 PM
  3. Why is my old phone picking up my new phone data.
    Last Post: 07-31-2017, 11:35 AM
  4. Love my Unlocked S8+ but how can I find MultiLine
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 07-31-2017, 11:34 AM
  5. Replies: 1
    Last Post: 07-31-2017, 11:33 AM
