1. Knix9's Avatar
    My s7 showing 10 hrs battery life after full 100% charge. Earlier it was much more battery life.please help
    08-30-2017 01:06 PM
  2. CWinkler's Avatar
    What's changed? Are you using battery optimizer? What's your Performance mode setting? Have you tried clearing cache? What apps are using up battery? What's your battery graph look like?
    Others might have more questions, so please jump in!
    08-31-2017 05:26 AM
  3. bedscenez's Avatar
    My S7 Edge is showing also 10 hrs and 30 minutes after
    full charge. Using Nougat and i notice that battery life is
    awful. turned off all settings that drains battery. Used skype for 1 hour and my battery is down to 75%.
    By the way after i updated i did a restore factory and clear cache..My a5 2016 in marshmallow battery life is better than my s7 edge.
    08-31-2017 11:45 AM
  1. Replies: 1
    Last Post: 09-26-2017, 06:29 PM
  2. Cant connect to google services on samsung galaxy tab 3
    By AC Question in forum Samsung Galaxy Tab 3 Rooting, ROMs, & Hacks
    Last Post: 08-31-2017, 11:56 PM
  3. Process system isn't responsive on my Galaxy S7.
    Last Post: 08-31-2017, 11:55 PM
  4. Samsung Galaxy s4 i9505, boot loop
    By mergehez in forum Samsung Galaxy S4
    Last Post: 08-31-2017, 12:41 PM
  5. How do I set my default storage to an SD card on Galaxy on5?
    Last Post: 08-30-2017, 03:33 PM
