1. XxBobbyXx88's Avatar
    Hello All,
    I recently began using a theme from Samsung Themes on my Galaxy S7.
    Will using a theme cause my battery to drain faster?
    Thank You
    1raygin likes this.
    09-12-2017 12:10 PM
  2. anon(238680)'s Avatar
    You always have a "theme" running, whether its the default when the phone is setup or one from the theme store. If you use a theme that has active wallpaper and animations then there is the potential to use more battery, but the same types of themes would use the same amount of battery.
    09-12-2017 12:19 PM
  1. Couldn't update because of low space on Samsung Galaxy S7
    By rickluc in forum Samsung Galaxy S7
    Last Post: 09-19-2017, 02:48 PM
  2. Battery doctor
    By Bill Zisopoulos in forum LG G6
    Last Post: 09-14-2017, 07:41 AM
  3. Does PictoScanner app work on Galaxy 8
    By Simon Lautrop in forum Samsung Galaxy S8 & S8+
    Last Post: 09-12-2017, 01:10 PM
  4. Speaker crackling on Samsung Galaxy J2 Prime
    By azurecrimsonrose in forum Ask a Question
    Last Post: 09-12-2017, 12:28 PM
  5. Does PictoScanner app work on Galaxy 8
    By Simon Lautrop in forum Ask a Question
    Last Post: 09-12-2017, 06:16 AM
