1. Ishraq Sk's Avatar
    About 2 weeks back, I noticed the back cover of my S7 opening from the side. It was followed by my phone suddenly restarting. I contacted the samsung service centre and they said the battery may be swollen up causing the cover to open, and must be replaced. My mobile has restarted several times on its own since then. Sometimes it reaches just the screen where it says Samsung and then begins to restart again, several times before it completely switches on and I can use it. Can i change the battery from India even though k have bought the mobile from Saudi Arabia? What else could be the cause of my mobile restarting if not the battery? Also, during the restart process, a screen saying "no command" has come up too. And ive had to format my phone several times in order to switch it on until it starts the same problem again.
    10-16-2017 03:46 AM
  2. yubeie's Avatar
    you can.. But would it be covered under warranty? .. I doubt it.. as long as you are willing to bear the expenses.. you should be able to get it repaired.
    10-18-2017 08:02 PM
  1. Why isn't my phone getting any notifications when connected to wifi?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 10-26-2017, 11:43 AM
  2. Where is private mode files located in samsung s5(marshmallow)?
    Last Post: 10-18-2017, 08:44 PM
  3. My 7 edge phone recognizing my 8gb stick but won t recognize 32 GB why
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 10-16-2017, 12:03 PM
  4. Re: My messages in the cloud are not deleting
    Last Post: 10-16-2017, 10:41 AM
  5. I deleted my download manger how can i recover?
    By Android Central Question in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 10-16-2017, 03:33 AM
