1. mcoomer's Avatar
    Hi all,
    I have a strange problem that has come up with my company owned S7. When I go to enter text in an app the cursor doesn't start at the beginning of the line and the first letter of text doesn't automatically capitalize. The cursor is a space or two to the right as soon as I tap in the field to enter text. I can hit backspace and move to the left and as soon as the cursor gets to the beginning of the line it will auto capitalize normally. This happens every time I open an app to enter text (text message, chat, Instagram, etc).
    Anyone else having this problem? Solutions?
    Thanks,
    Mike
    tmb8000 likes this.
    10-20-2017 03:57 AM
  2. SpookDroid's Avatar
    Does it happen with any keyboard or just with the stock Samsung one?
    10-20-2017 02:02 PM
  3. NiffiIsenguard's Avatar
    have you tried to do a soft reset? or even a system cache clear?
    And What SpookDroid Said as well If your using stock for some reason on mine it as a couple quirks. Switched to Gboard and never looked back
    10-20-2017 04:06 PM
  4. mcoomer's Avatar
    Sorry for the delayed response. Traveling. I believe it is the stock keyboard, with Swype. I'll take a look. I do partition cache clears on a regular basis. Seems to help keep things running more smoothly.
    I'll check on the keyboard and report back.
    Edit: It was the stock keyboard. Just enabled Gboard. We'll see.
    Thanks,
    Mike
    SpookDroid and tmb8000 like this.
    10-23-2017 11:14 PM
  5. SpookDroid's Avatar
    Let us know if that helps. I personally prefer SwiftKey to the Google Keyboard, but it's up to preference.
    10-24-2017 01:04 PM
  1. Text Message only pulling up image not text?
    Last Post: 10-21-2017, 01:41 PM
  2. Replies: 1
    Last Post: 10-21-2017, 01:40 PM
  3. Replies: 1
    Last Post: 10-20-2017, 01:15 AM
  4. multiple bluetooth problems with S8
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 10-19-2017, 10:13 PM
