1. DeepSkyDiver's Avatar
    Still on Android 7.
    Here's what I see:
    The hardware home button only responds intermittently, even using the Fingertouch service doesn't always get a response. Sometimes I can press the button 4 times.
    Apps sometimes take seconds to respond
    On the lock screen the phone is often not responsive at all. About half the time now I see:
    * the volume buttons do nothing
    * dismissing a notification leaves a grey background, but the notification remains
    * the fingerprint unlocking doesn't always work. Sometimes it will unlock halfway through typing in my PIN when it catches up to the lag..
    I don't want to reset it because I don't want to spend hours setting it up again - and let's face it I shouldn't have to.
    Anyone else come across this and have insight into what if anything specific might be behind the symptoms?
    I'd heard of the Samsung lag, though I had no idea how bad it could be. I haven't got a huge number of apps and nothing unusual, certainly nothing not from the Play store.
    11-05-2017 05:16 PM
  2. chanchan05's Avatar
    No issue on mine, using an Exynos S7 Edge with Nougat 7.0
    I'd suggest a cache wipe. You could also try running device maintenance i settings to see if it helps.
    Laura Knotek and DeepSkyDiver like this.
    11-05-2017 07:36 PM
  3. DeepSkyDiver's Avatar
    Thanks - I've wiped the cache partition and report back how that goes.
    11-05-2017 08:50 PM
  4. DeepSkyDiver's Avatar
    It's certainly much better in the wake of that and still a day later. Thanks again for your help!
    11-07-2017 12:11 AM
  1. Replies: 2
    Last Post: 11-05-2017, 05:11 PM
  2. Galagy S6 Edge stuck on T-Mobile logo white screen & flashing blue light
    Last Post: 11-05-2017, 02:55 PM
  3. Galaxy s 3 screen not responsive, not wet, just stopped!
    Last Post: 11-05-2017, 02:02 PM
  4. Galaxy S7 Black screen
    Last Post: 11-05-2017, 12:12 PM
  5. rSAP in car email issue on Samsung Galaxy S7 in Audi S3
    By Essooil in forum Samsung Galaxy S7
    Last Post: 11-05-2017, 10:08 AM
