1. Psturges's Avatar
    I want to remove some unused bluetooth devices but there is no settings icon next to thr device. Have tried going to settings several ways but nothing works. Help going nuts.
    It appears that the icons are the same color as the back ground they were there just couldn't see them DUH.
    12-03-2017 05:03 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are those Bluetooth devices nearby when you do this? They might just be showing up because your phone's Bluetooth is on and reporting what devices are nearby.
    If they're not nearby, then what happens if you long-press the device listing?
    12-03-2017 08:57 PM
  3. Psturges's Avatar
    Cheers for reply it was just Monday messing with my brain.
    B. Diddy likes this.
    12-03-2017 10:33 PM
  4. B. Diddy's Avatar
    Oh whoops -- did I miss your solution in the original post, or did you edit it to include the solution?
    12-03-2017 11:06 PM
  1. So happy to be back!
    By swagglepuff in forum Essential Phone
    Last Post: 12-05-2017, 09:50 AM
  2. What icons are these apps for please
    By hollydarlaston in forum Android Apps
    Last Post: 12-05-2017, 03:32 AM
  3. Upgrade from Galaxy Note 10.1 2014 to Zenpad 3S 10?
    By AMG_Roadster in forum ASUS ZenPad 10.0
    Last Post: 12-03-2017, 09:51 PM
  4. Replies: 1
    Last Post: 12-03-2017, 09:16 PM
  5. How do I transfer picture gallery to my SD card on my galaxy note 8?
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 12-03-2017, 09:00 PM
