A
Android Central Question
I recently purchased a used s7. On verification of imei it shows that it's g930p device which should be running on sprint. Besides the device is verified as paid and financially cleared on sprint. But device is running on t mobile software. Why is it so. The device imei on back cover and software is same.
Besides the device is running all OK and getting all updates from the mobile. The only issue is that I am unable to connect it to computer using usb. Tried almost all options from usb debugging to usb options and changing cables.
Are bothere issues related.
