1. angusrose's Avatar
    Hi all,
    I have a Galaxy S7 Edge and I need to connect it to my turbo trainer via ANT+. From what I've read, this phone is already ANT+ enabled and so connecting the two should just be a case of bringing them within range. However, using apps such as trainerroad, I see a 'paired' notification but when I start pedalling I see no change in cadence or power. Is there something I need to install on the phone other than the ANT+ Service Plugin and ANT+ Radio Service?
    Thanks
    Angus
    01-22-2018 03:43 AM
  1. display light auto on and off
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 01-28-2018, 09:30 PM
  2. Samsung Note 8 keeps crashing
    By Jezahb in forum Samsung Galaxy Note 8
    Last Post: 01-22-2018, 11:46 AM
  3. Why does my Samsung Galaxy J7 Prime have an installation block?
    Last Post: 01-22-2018, 06:30 AM
  4. My contacts just dissapeared in samsung s7 edge
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 01-22-2018, 03:37 AM
