Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main
Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/gen...d-central.html
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
Regarding the installation message -- use a file manager app to look directly in the /Download directory, and see if there are any suspicious apk files there.
