1. galaxy_mess7's Avatar
    Original question:
    Samsung Galaxy S7 owner here. At some point, the original battery got bloated, so I decided to replace it. After the replacement, with the new battery, the phone wouldn't charge and would turn off after as soon as I removed the charging cable. Charging percentage would show a random constant number (the favourite was between 57 and 60 but could vary).
    So I took the new battery off and plugged the charger in without a battery attached. And guess what? The phone shows a random charged percentage (this time fav range is 35-40%).
    Tried hard resetting, pressing the power button to drain the capacitors, clearing the cache, nothing helped so far. I am clueless where that number could come from and I am guessing that when the battery is hooked on, the phone doesn't even recognise it.
    Any help appreciated!
    PS:
    Someone asked how I removed the battery, since the S7 is 'built with unremovable battery'. Google and Youtube can answer that.
    03-06-2018 05:29 PM
  2. dbollman423's Avatar
    I am not an electrical engineer but my guess is that the battery meter does not measure whether it is plugged in or not. It measures the battery, which is not installed.
    I believe the memory is like a flash drive and is showing the last reading adjusted for capacitors discharging between the meter and where the battery used to be.
    I took mine to Batteries + Bulbs and had the battery changed 2 weeks ago for ~$64.00. It has been working very well since then and only took a couple of hours.
    03-09-2018 07:03 AM
  1. I want to upgrade to the Galaxy S9+ from my Galaxy S6. Should I do it?
    By EPIC_VIC_951 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-12-2018, 06:35 PM
  2. North Korea rejected the Olympic edition Note 8!
    By Blues Fan in forum Samsung Galaxy Note 8
    Last Post: 03-07-2018, 01:03 PM
  3. S7 shows charged percentage even with BATTERY REMOVED, ignores the battery
    Last Post: 03-06-2018, 06:57 PM
  4. Safe to remove back cover of phone?
    Last Post: 03-06-2018, 05:15 PM
  5. what newer smartphone is the best upgrade from a Motorola Droid Maxx
    Last Post: 03-06-2018, 04:35 PM
