1. I_didnt_do_it's Avatar
    I downloaded chronus a couple weeks ago for the customization options and how well it fit with my current theme. However, now I notice my battery usage, as alluded to before, is quite a bit more significant than it was for the first month and a half I had my S7. I noticed after downloading chronus, the battery drains at a much faster rate, and Android system is now taking up significantly more power than it used to. Before it was using only about 1-3% of the total battery discharge, now it's up at 10%. Did not do this until after installing chronus.
    03-10-2018 06:07 PM
  2. SpookDroid's Avatar
    Have you checked the update frequency for the widget? If it's set to update a lot, then that would drain your battery. Also, widgets that are graphically intensive will use more resources every time you see them on screen, so if you use that a lot it also will impact the battery life.
    03-10-2018 06:30 PM
  3. I_didnt_do_it's Avatar
    I currently have it set to update every 60 minutes.
    03-10-2018 06:37 PM
  4. I_didnt_do_it's Avatar
    uninstalled it and went to the stock weather widget. battery drain back to a good level, and Android system is back down to its usual 1-3% of the total battery use. Guess it just didn't gel with how I have it set up.
    03-11-2018 12:19 PM
  1. Amazon fire stick won't use my wired connection?
    By psongman in forum Amazon Fire TV
    Last Post: 01-03-2019, 08:27 PM
  2. Exchange using up battery - what is this?
    By sethm1 in forum LG V30
    Last Post: 06-04-2018, 10:20 AM
  3. Verizon Note 4 - refusing to use (non-verizon) SIM card.
    By manhattan212 in forum Samsung Galaxy Note 4
    Last Post: 03-10-2018, 03:45 PM
  4. download another keyboard using a PC to your phone
    Last Post: 03-10-2018, 02:47 PM
  5. Why S8 plus doesn't show the fast dialing screen that I used in my S7?
    Last Post: 03-10-2018, 01:44 AM
