    Since I can connect to other networks with no problem, I suspect that somehow my home network is being blocked for some reason. It disconnects in 3 seconds.
    I have tried 'forgetting' the home wifi, resetting everything. It still doesn't work.
    Suggestions?
    03-11-2018 03:47 PM
  2. Rukbat's Avatar
    Have you restarted your router? (There should be a little button on the back - it may be recessed - to restart it.)
    If that doesn't fix it, try the 30-30-30 reset:
    Hold the reset button in for 30 seconds. Still keeping it pressed in, remove power. Keep power removed for 30 seconds. Reconnect the power and keep the reset button in for another 30 seconds.
    Now it's factory reset. (Look in the manual for the login and/or password.) Set it back with your old password and encryption (probably SPA2 Personal/AES) so everything else can still sign in.
    Now try connecting your phone.
    03-11-2018 04:57 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! See also this guide for more tips: http://forums.androidcentral.com/amb...-problems.html
    03-11-2018 05:19 PM
  1. Galaxy S9+ Fingerprint scanner not working
    Last Post: 11-18-2018, 09:07 PM
  2. When will we see the Microsoft/Android Integration go to the Next level?
    By AMTrombley0924 in forum General News & Discussion
    Last Post: 03-12-2018, 10:27 AM
  3. Facebook app can't connect
    Last Post: 03-11-2018, 07:09 PM
  4. Galaxy S7 Wi-Fi not working Sprint
    By Kgray 7 in forum Samsung Galaxy S7
    Last Post: 03-11-2018, 05:26 PM
  5. the clock/weather widget on my Galaxy S8 shows 2 different times
    Last Post: 03-11-2018, 03:39 PM
