Save big + get 3 months free! Sign up for ExpressVPN today
  1. Eric Hough1's Avatar
    My Samsung S7 is running nougat 7.0 and is dumping battery, losing as much as 45% in 1-2 hours with zero usage. Cpu usage is typically 90%+ with no apps running and zero personal use.
    I've tried clearing cache via storage menu and with DOS mode.
    Downloaded GSAM and have all the information avail from charts, etc. Not sure how to post these screen shots though.
    Attached Thumbnails Samsung S7 Battery Drain w/ high CPU usage-screenshot_20180429-204620.jpg   Samsung S7 Battery Drain w/ high CPU usage-screenshot_20180429-204128.jpg   Samsung S7 Battery Drain w/ high CPU usage-screenshot_20180429-204124.jpg   Samsung S7 Battery Drain w/ high CPU usage-screenshot_20180429-204120.jpg   Samsung S7 Battery Drain w/ high CPU usage-screenshot_20180429-204115.jpg
    Samsung S7 Battery Drain w/ high CPU usage-screenshot_20180429-204107.jpg
    04-29-2018 10:58 PM
  2. djrakowski's Avatar
    App usage indicated in the first screenshot seems awfully high. Is there any more information behind that number to indicate which app(s) are consuming so much power? I suspect one of your apps is churning away in the background.
    04-30-2018 07:25 AM
  3. Javier P's Avatar
    Welcome to the forums. I agree with djrakowski, that's a very high app usage percentage. I recommend you to check your battery stats from the settings instead of Gsam and see which app(s) are top of the list.
    djrakowski likes this.
    04-30-2018 08:27 AM
  1. Got two batteries from ebay-dated
    By dlcpa in forum LG V20
    Last Post: 05-14-2018, 10:29 AM
  2. Replies: 1
    Last Post: 04-30-2018, 03:35 AM
  3. Optimal settings for s7 edge
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 04-29-2018, 06:41 PM
  4. Is there a microphone available for the Samsung J3 keyboard
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 04-29-2018, 03:40 PM
  5. Is there a microphone available for the Samsung J3 keyboard
