1. rguedel's Avatar
    I have a Galaxy S7 and have recently started receiving pop-up ads with sound that take over my screen even when the phone is on Do Not Disturb. It looks like they could be coming from Google Play as they have a triangle in the corner. I have gone to the Google Play App to block notifications but that doesn't seem to be working. I don't see any malicious apps that I can see in my apps. Does anyone have other suggestions other then a factor reset?
    05-26-2018 06:53 PM
  2. B. Diddy's Avatar
    They're not from Google -- Google doesn't do this kind of thing. You probably inadvertently installed some adware along with some other app. Uninstall apps one by one until this behavior goes away.
    05-27-2018 10:26 PM
  1. Possible 8GB RAM and 512GB of ROM on the Galaxy Note 9!
    By Preach2k in forum Samsung Galaxy Note 9
    Last Post: 06-08-2018, 10:06 AM
  2. Notification bar, home and recent tabs not working in Nexus 6
    Last Post: 05-27-2018, 10:45 PM
  3. What is com.qualcomm.location.XT
    Last Post: 05-26-2018, 09:09 PM
  4. Replies: 0
    Last Post: 05-26-2018, 06:18 PM
