1. BoostedPenguin's Avatar
    Hey so.. Phone's root bugged out yesterday and I downloaded twrp and decided I should upgrade it to Android 8.0 then root it. After many hours of failures I managed to flash a 8.0 but I couldn't make the CSC to work, since my phone is region locked to another country so I decided to go back to 7.0 and try again.. but now here it gets complicated because I really don't know what to do. I'm not sure how exactly to go back from 8.0 to 7.0.. Can someone give me detailed steps on what should I do.. I'd be very grateful!
    07-01-2018 03:51 AM
  1. not able to add contacts in samsung galaxy on max.
    Last Post: 07-01-2018, 03:11 AM
  2. Samsung S7 Edge Battery Drain
    Last Post: 07-01-2018, 02:24 AM
  3. will Samsung Galaxy S4 earphone jack double as an external antenna Jack
    Last Post: 07-01-2018, 12:26 AM
  4. Replies: 0
    Last Post: 06-30-2018, 11:26 PM
  5. Replies: 0
    Last Post: 06-30-2018, 11:04 PM
