    I use a galaxy S7, and using Accubattery, I usually use 25-30% of battery on screen per hour. However, after downloading Nova, It went up to 35-40%. I really don't want to delete nova because it looks good on my phone.
    10-24-2018 01:38 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it actually say that Nova is using a lot of battery? Has this increase been consistent, or only temporarily after you installed Nova? After installing Nova, it takes a little while to set up you homescreens the way you want them, so that could contribute to increased battery usage. Give it a few more battery charge cycles and see if the battery life returns to normal.
    10-25-2018 08:15 AM
  3. Rukbat's Avatar
    AMOLED screen. Is the wallpaper glaringly white, with few icons? That eats battery like a starving man eats food. Change to a solid black wallpaper and watch it drop through the floor. And if you install Proximity Service and keep the phone screen-down, or any way that you trick it into thinking that your ear is against the screen when you're not using it, you'll save a few more percent.
    10-25-2018 11:42 AM
  4. deltaa350's Avatar
    Thanks for the comments, but it is fixed. It had a large surge of battery usage the day I installed it, and a few days later, but it is back to normal. And no, I already use an all black screen for my background.
    B. Diddy likes this.
    10-25-2018 06:46 PM
  5. FiOS Dan's Avatar
    Seems high. I average 17.4%/hour when the screen is on according to Accubattery.
    10-26-2018 09:41 AM
  6. deltaa350's Avatar
    hmm interesting I usually always have 25-30% and recently 35%, even without Nova launcher. My battery health is at 75% which might be why
    11-01-2018 06:06 PM
  7. FiOS Dan's Avatar
    Possibly, mine is at 91%.
    11-02-2018 09:03 AM
  1. How to get forgotten WiFi back and why is it not working on any other device
    Last Post: 10-25-2018, 09:45 AM
  2. Okay my note9 is hacked they use screens
    Last Post: 10-25-2018, 09:40 AM
  3. I cannot get my Google Home to reconnect to the android GH app
    By Android Central Question in forum Google Home
    Last Post: 10-25-2018, 08:16 AM
  4. My note 9 charging very slow when switched off
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 10-24-2018, 06:30 PM
  5. I keep getting ads on my home screen by google chrome
    Last Post: 10-24-2018, 02:36 PM
