You didn't full answer mooncatt last question? Check safe mode if you still having the issue? Also if that's the original battery you only going see a decrease .
That is correct, safe mode is your phone diagnostic mode and will turn off all 3rd party apps like your windows computer in safe mode, you can observe battery drain if its the same and if it's not means most likely a 3rd party app is draining the battery.Thanks for the reply! To do safe mode would that be to just do what B Diddy said in post 5 when he referred me to the T-Mobile external site? But I'm not even sure what to do in safe mode once it pulls up or what I'm even looking for to solve my issue?
Yes you can stay as long as you like in safe mode to determine , you wont have 3rd party apps work but can get message and phone calls, and to exit out just reboot.Ok thanks guys! So basically do the steps in the link on post 5 for going into safe mode and then just see if my battery drains the same way as always? That's all I need to do? Nothing else and just report back here? What if it's too close to call on whether it's the same or not drainage wise?
Also, do I need to be in safe mode for a specific amount of time, etc. to do this? Can calls/texting still come through and work like normal while in safe mode?
Safe mode will disable all 3rd party apps to see if any of them are acting up , you still get to make calls and text . It's a diagnostic function , so we try this and see the results .Ok thanks! Another question before I try safe mode like recommended....is it worth noting that my phone usually doesn't seem to drain battery as quickly when I'm not using it? It seems to be only a lot more when I'm obviously using it and on apps, etc. But when I'm not, it doesn't seem to have the problem as bad.
With that being said, should I still try safe mode? Just wondering if that definitely means it's the apps or something else, etc.
If I do safe mode, do I basically just do the steps in the link on post 5 for going into safe mode and then just see if my battery drains the same way as always? That's all I need to do? Nothing else and just report back here? What if it's too close to call on whether it's the same or not drainage wise?
We just want confirm if a 3rd party app that's allThanks! Yeah, I understand that. But what I'm saying is, if my phone doesn't seem to drain as much when I'm not using it compared to when I am using it, doesn't that already mean that it is the apps causing the problems? And do I even need to go into safe mode? Just wondering if running safe mode is going to be the same as me not using apps not in safe mode? Make sense?
Just curious.
Best way is to fully charge your battery run it down to 20 % and look at the battery stat see what's going on .
You can do both and compare nothing wrong with that .Thanks, makes sense. But wait, I'm confused on your last line. Are you saying to do that while I'm in safe mode? Because I thought I was told when I try safe mode to not do anything except notice if the battery drains the same or not?
Or do you mean not in safe mode? Because if not in safe mode, I already did that and showed my results on Page 1?
Device care doesn't turn off in safe mode to check the stats.I'm confused though, how can you look at a battery statistics screen while in safe mode? I was told in safe mode all you can do is limited functions like use the phone and message? And I already provided a battery statistics screen on page 1 while I'm not in safe mode, does that not help?
Sorry, just confused. Because I thought when I do try safe mode, it's only to check the battery drainage with my eye and I thought you couldn't check statistics screens, etc. that you normally can. But regardless, everyone that said to try it in safe mode didn't talk about looking at reporting screens, etc. if you can, until you did now?
Thanks.
