Keep this in mind if you plan on moving from an S8/S8+. In the last month I decided to setup my Edge Panel on my S8+ and got all used it and realized it wasn't on the Active. Not a big deal to me though just thought people should know.
For sure, just thought I'd put it out there for folks who are trying to compare the two and over look the edge panel feature of they happen to use it a lot. But yeah I'm not dependent on it and don't mind not having it.The reason I got an S7 Active instead of an S7 Edge when they took away my Note 7, was I could not stand that Edge Panel. My fingers kept triggering things when I didn't want them to trigger! So, I purchased the S7 Active instead and love it... now I am looking at it's replacement, the S8 Active.
Why would you expect an Edge Panel on a Flat Screen folks? Just because this says S8? It's a different phone with a flat screen and I, for one, am happy that it does not have an Edge Panel! Thank you Samsung!
The chick at the ATT store had an S8, in a case, with a cracked screen. She said it was the 3rd or 4th S8 she had cracked. Edge this.
