The best 10 Galaxy S8 and Galaxy S8+ drop protection case for men
1.SHIELDON Galaxy S8/S8+ Drop Protection case - Sunrise Series, Dual Layer Case - $ 15.99/$ 16.99
Feature:
- Protected enough but very thin
- The SHIELDON Galaxy S8 Case provides full protection, 4 thickened TPU cushion corners ensure the phone against drops and bumps; Raised edges and the 4 extra 1MM Raised Pads on the bottom of the TPU case to protect the screen, camera and the slim hard back case from scratches and dirt
- 2 IN 1 Hybrid dual-layer design, features a soft TPU Inner Protective Case and a Hard Polycarbonate Back Frame Cover
- The 3D textured internal design holds the phone steadily, reduces the force from drops and lessens the heat via improving airflow
- 4 Extra 1MM Raised Pads on the bottom. Lift the case off the ground, protect the slim back case from scratches and dirt.
2. Otterbox Galaxy S8+ Symmetry Series Case - $49.95
FEATURES
- Stylish designs: eye-catching colors dress up your device
- Slim profile: sleek design slips easily into pockets and purses
- Screen bumper: raised, beveled edge helps protect touchscreen
- Easy installation: one-piece design slips on and off in a flash
3. Spigen Galaxy S8 Tough Armor Case - $ 34.99
FEATURES
- Extreme dual-layer protection made of a TPU body and PC back
- Precise cutouts for quick access and raised lips to protect screen and camera
- Reinforced kickstand for hands-free viewing experience
- Slim profile and tactile buttons for quick responsiveness with a seamless look
- Mil-Grade certified with Air-Cushion Technology® in all corners
4. Caseology GALAXY S8 CASE PARALLAX -$ 13.99
- This Galaxy S8 case features a 3D geometric pattern that provides a solid grip.
5.Speck Galaxy s8 Presidio Grip Case - $39.95
- Shock Barrier. IMPACTIUM is a dynamic shock-suppression material that lines the case. -
Ridges of IMPACTIUM on the inside perimeter compress on impact to absorb and disperse shock
- Patented raised-bezel screen protection. IMPACTIUM raised bezel guards screen from direct drops onto phone face and prevents damage when lying flat
6.X-Doria Galaxy S8 Defense Lux Case - $34.9
- Military grade, durable, machined aluminum exterior frame providing military-level drop protection in a slim, pocketable and premium case
- Soft rubber interior lining combined with a hard polycarbonate shell for protection. Raised lip protects your screen from drops and surface scratches
- Drop tested to survive 6.6' (2M) drops on concrete exceeding MIL-STD-810 Standards
- Simple snap on construction means no tools or screws required
7.Supcase Galaxy S8 Unicorn Beetle Case - $ 14.99
- Constructed of high-grad Polycarbonate and TPU
- Clear scratch-resistant rear plate
- Edges ensure phone face is recessed for protection
- Slim and stylish; Will not interfere with phone functions or buttons
8. Lumion Galaxy S8 Nova Series Case - $11.99
- Slim-fit, stylish design keeps your device thin and bulk-free
- Lightweight polycarbonate secures your device and leather detail adds style
- Button and camera cut-outs allow full access to all device functions
- Easy installation so you can use your device right away
9. MNML Ultra Slim Case Galaxy S8 - $ 14.99
https://www.amazon.com/dp/B06XGPR812?tag=hawk-future-20&ascsubtag=UUacUvbUpU5805411
- ULTRA THIN
- PERFECT CUTOUTS - exposed buttons and ports are perfectly cut giving you full easy access. The camera cutout has a raised bump to protect your camera on surfaces. The front of the case has a raised rim to protect the phone’s screen from scratching.
10. Poetic Affinity Galaxy S8 Case - $ 9.95
rity to showcase the best that your device has to offer. Drop protection with engineered corner design
- Raised TPU back material to prevent scratching while maintaining full clarity of the device
- Inner ridged TPU surface to enable effective shock dissipation while keeping a thin form factor. Raised bezel for front face protection. Extremely thin with the maximum protection in its class.
Feature:
FEATURES
FEATURES
- ULTRA THIN
