My Galaxy S8 pls fall to the ground and the screen was broken so I need to replace it. I find a Samsung Galaxy S8 Plus screen assembly replacement on Etrade Supply, does it worth to buy? And how much do you think the price is suit?
Remember, if you have Samsung replace screen you'll retain water resistance. When it comes to water resistance 3rd parties are a crapshoot. You usually get what you pay for in relation to screen replacement. As new to market S8 is I wouldn't personally trust anyone but Samsung. I want to say someone said Samsung is quoting ~$300 to replace screen and 8-10 day turn around time. May be slightly off but from my old memory...Welcome to Android Central.
To be honest I wouldn't consider anyone but Samsung to replace my screen. Cost can vary from $150 up to $500. Just depends on who you want to do it.
