1. Tl2eVol2's Avatar
    Im always listening to headphones at home with a galaxy S8 Plus ..i do not own any type of amp or dac but with poweramp and frostwire i can acheive tolerable quality audio/clean hard bass in my opinion 10 times better then my old spotify or tidal whitch i use now every few days instead of spotify because of the much better audio and new release metal tracks. HOWEVER ...my question is....if I root my s8 + can I get better sound quality from my phone??? Or is it just like every EQ we try with the same mehh effect? I want to root just to try this Viper program. Is it really that good? Or will the phone still only produce the quality of audio the "sound card" was made to produce? Any advice,comments, opinions, or burns/haten would be greatly appretiated. Thanks. •••Trevor
    12-12-2018 12:08 AM
  2. Golfdriver97's Avatar
    I've never heard of root access to give better sound. Root access is typically needed for making admin level changes to the OS. It is possible, though, in case Samsung has a software limitation on the audio hardware itself, but for some reason, I doubt that.
    Some caveats:
    1. Rooting voids any warranty you may still have.
    2. Rooting can lead to a bricked device (very rare, as long as you follow all directions for you exact device model).
    3. Root blocks OTA updates.
    4. Samsung has been trying to block root access for quite some time. Depending on your carrier, it may be impossible. The last I knew there were still some bounties on Verizon and AT&T Samsung devices as far back as the 7.
    12-12-2018 08:53 AM
  3. stormaudio's Avatar
    Yes .. rOOTING ENABLE YOU TO INSTALL CUSTOM kERNELS THAT HAVE ADVANCED TWEAK FOR aUDIO
    11-17-2019 12:20 AM
  1. Which one is better choice?
    By Vitno in forum Buyers Guides
    Last Post: 01-26-2019, 07:17 AM
  2. Replies: 1
    Last Post: 12-13-2018, 05:09 PM
  3. Delete files from root directory /document
    Last Post: 12-12-2018, 04:35 AM
  4. Will the SimCard work in a mobile hotspot device?
    Last Post: 12-11-2018, 10:18 AM
  5. How do you root oppo A3s, does anyone know please help me
    By Noftra as bob in forum General Help and How To
    Last Post: 12-11-2018, 08:27 AM
