1. Safehorses's Avatar
    Hello all. I have a question about phone life after having battery replaced from swelling. Galaxy S8 battery swelled and broke back glass. Once the battery and glass are replaced should the phone be fine or should I just look for a replacement phone? I don't want to spend the money to have it repaired if it's worth it. Thank you
    10-18-2020 09:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Assuming the battery didn't start leaking, then it should still work fine after a battery replacement. The IP water resistance rating will be nullified, of course.
    10-18-2020 09:41 AM
  3. mustang7757's Avatar
    How much would it cost to be repaired?
    I had same happened on my s8+ but it took the back glass off without breaking , never fixed it though but just needs battery .
    10-18-2020 09:44 AM
  1. Is Smart Call included on factory unlocked Galaxy S10
    By pbike908 in forum Samsung Galaxy S10 & S10+
    Last Post: 10-17-2020, 04:21 PM
  2. ECG Galaxy Watch Active 2/Watch 3
    By MarineDawg in forum Microsoft Surface Duo
    Last Post: 10-17-2020, 02:44 PM
  3. 3D Galaxy Warrior - Space Shooter
    By thedgames in forum Android Games
    Last Post: 10-17-2020, 02:34 PM
  4. Is Smart Call included on Factory Unlocked Galaxy 20 or S20 FE
    By pbike908 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 10-17-2020, 09:58 AM
  5. Replies: 2
    Last Post: 06-14-2014, 02:05 AM
