    I use an unlocked Samsung Galaxy S8 and Jlab Jbuds Air Icon true wireless headphones. The headphones connect just fine and sound comes through just fine. Sometimes while I'm on calls tho, the people on the other end can't hear me well or hear me at all. I have a feeling it has to do with mic sensitivity and background noise cancellation but I don't know how to fix it.
    11-09-2020 02:22 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Some Bluetooth headphones are better than others when it comes to phone calls. Make sure the mic opening of the buds is clear of any debris. Also, go to Settings>Bluetooth, tap the gear next to the buds, and make sure Phone Audio is turned on.
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    Tech Idiot likes this.
    11-09-2020 04:00 PM
  3. mustang7757's Avatar
    Make sure the mic on headphones are clean from dirt
    11-09-2020 09:10 PM
  4. mustang7757's Avatar
    [Moved your question to s8 Forums]
    11-09-2020 09:11 PM
  1. One of my google account vanish. How to fix it?
    Last Post: 12-12-2020, 01:06 PM
  2. How many system apps should a Samsung s6 have installed?
    Last Post: 11-09-2020, 11:18 PM
  3. My LG Aristo 3 is stuck on the firmware update screen at 0% how can I restart it?
    Last Post: 11-09-2020, 09:09 PM
  4. Can I stop the Sandisk from downloading files so I can charge phone?
    Last Post: 11-09-2020, 08:55 PM
