1. Tech Idiot's Avatar
    Speakerphone works great, bluetooth through my car works great...but when I hold the phone to my ear, the call volume just isn't great. I set it as high as it goes. Are there any other settings which I can change that might improve this? Thanks in advance!
    11-21-2020 12:32 AM
  2. mustang7757's Avatar
    Hi, have you tried raising the volume once again while in call sometimes it can adjust more ?
    Tech Idiot likes this.
    11-21-2020 10:02 AM
  3. Tech Idiot's Avatar
    Yes, I've done that, using both the button(s) and the slide bar...and I do it virtually every call, LOL.
    I've looked around at various settings, but I have no idea what they are. Is anyone aware of any specific settings I can turn on, turn off, etc.? Thanks again.
    mustang7757 likes this.
    11-21-2020 01:34 PM
  4. mustang7757's Avatar
    Do you have a toggle for Dolby Atmos?
    11-21-2020 01:38 PM
  5. B. Diddy's Avatar
    Make sure the earpiece speaker opening isn't clogged by debris like lint.
    11-21-2020 02:00 PM
  6. Tech Idiot's Avatar
    I did a search in settings and nothing came up, but I looked all over anyway, and yes, I have a toggle for this...but it is "grayed out" and I can't access/turn on-off. Thanks!
    Please tell me I don't have to take the phone apart for this?!?!? LOL. I did use a compressed air can on it, but it seemed like a waste of time. Other than shooting it with compressed air, is there anything else to do? Thanks!
    11-22-2020 07:20 AM
  7. mustang7757's Avatar
    Greyed out ..hmmm
    You try safe mode ?
    You use samsung sound assistant?
    11-22-2020 09:54 AM
  8. B. Diddy's Avatar
    On second thought, that's probably not the cause. I looked at an image of the earpiece speaker opening for the S8, and it doesn't look like it be at risk for getting clogged up, since it's a line about an inch long. If it were a small circular opening, that would make it more likely.
    Here are the steps for Safe Mode: https://www.t-mobile.com/support/dev...sung-galaxy-s8
    11-22-2020 12:36 PM
  9. Tech Idiot's Avatar
    Greyed out ..hmmm
    You try safe mode ?
    Safe mode? You mean boot up in safe mode? Uggh...is that really going to be safe for someone like me to do? So boot up in safe mode, get to the Dolby Atmos screen and see if I can turn it on then?
    I don't know what sound assistant is, so my guess would be no, I am not using it. Thanks.
    11-23-2020 11:32 AM
  10. Tech Idiot's Avatar
    Yes, on my S8 PLUS...it's a straight line/small channel, very thin, with a mesh grill. I've blown it out with compressed air, but that doesn't seem to do anything. You would have to think after time and time again put the phone to your ear...it is going to get dirty, clogged, etc.
    11-23-2020 11:34 AM
  11. mustang7757's Avatar
    Yeah , to get into safe mode long press power button then on the screen it will say power off long press that then tap safe mode , to exit out any time just restart the phone, yeah I want see if you can toggle Dolby tin that mode and also check the volume whole your in It.
    11-23-2020 11:40 AM
  12. Rukbat's Avatar
    Bad idea - that can blow the lint further into the opening. Don't do that in the future. Ise a bright light, a magnifying glass and a pointer wooden toothpick.
    11-23-2020 01:54 PM
  13. Tech Idiot's Avatar
    Uggh! OK, thanks. Sorry I did that. However, I can't use a toothpick -- maybe a super small pointed one or something like that -- the holes are way too small, and there's tons of them, LOL. I guess I could use a pin. Thanks again!!!
    11-23-2020 08:38 PM
  14. mustang7757's Avatar
    Uggh! OK, thanks. Sorry I did that. However, I can't use a toothpick -- the holes are way too small, and there's tons of them, LOL. I guess I could use a pin. Thanks again!!!
    A toothbrush is good enough
    11-23-2020 08:38 PM
  15. Tech Idiot's Avatar
    Great idea!!!
    11-23-2020 08:40 PM
  1. Subscription to discontinued app
    By ATDRs in forum General Help and How To
    Last Post: 11-20-2020, 10:37 PM
  2. Subscription to discontinued app
    By ATDRs in forum Android Apps
    Last Post: 11-20-2020, 08:25 PM
  3. During a call my screen will not let me make selections. I have a Blu vivo XL4.
    Last Post: 11-20-2020, 06:41 PM
  4. [GUIDE] How To Avoid Malware
    By B. Diddy in forum Ambassador Guides, Tips & How-To's
    Last Post: 11-20-2020, 06:27 PM
