I had the battery in my Samsung 8+ replaced. The new battery is 3,850 mAh.
When I open Settings, scroll down to About Phone, and touch Battery information, it
displays the Battery capacity as 3,500 mAh, which was the capacity of the old battery.
Is there a way to update that? Or is it set at that permanently? If it's changeable, will
it actually effect anything, like charging time or time of battery usage?
Thanks.
Thanks.
