1. paulb104's Avatar
    I've got a 512gb flash drive that the S8+ cannot see. I could keep reformatting the drive over and over with different file systems and sizes to figure it out but I'm hoping someone will know...
    The drive I have is like this https://www.amazon.com/SanDisk-512GB...cUvbUpU6975768
    08-30-2021 12:40 AM
  2. BergerKing's Avatar
    • 256 GB is the limit for the S8+, as I understand it. I remember that from when I had it, myself. That's internal and external OTG.
    paulb104 likes this.
    08-30-2021 01:01 AM
  3. mustang7757's Avatar
    You checked in your file manager ?
    Samsung My Files should see it popluate there
    08-30-2021 01:03 AM
  4. paulb104's Avatar
    The phone simply doesn't see the drive. I've had both the drive and the phone for years, and I've tried a number of things. I've never reformatted the flash drive though. I'm thinking about it, but I've got a *lot* of stuff on it to take off of it first... 512GB holds quite a bit...
    08-30-2021 01:18 AM
  5. mustang7757's Avatar
    Have you tried it on the computer to see if it works?
    08-30-2021 01:19 AM
  1. Samsung Calendar Notifications on GW4
    By neo999 in forum Samsung Galaxy Watch 4
    Last Post: 09-04-2021, 11:36 PM
  2. Which is the best browser?
    By marthaHoopkins1976 in forum General Help and How To
    Last Post: 08-31-2021, 09:44 AM
  3. Solved: phone calls on LG G7 not working
    Last Post: 08-29-2021, 09:34 PM
  4. Can I disable Autoscan for new media on VLC?
    Last Post: 08-29-2021, 08:32 PM
  5. Find IMEI number on Scepter 8 tablet
    By Roger Blair in forum General Help and How To
    Last Post: 08-29-2021, 01:35 PM
