1. BluBrett's Avatar
    The last thing I want on an AMOLED display is a navbar, so I hope they integrate the 3 necessary buttons as gestures or something. The leaks are not showing any sort of navbar at the bottom so far. Some leaks also suggest Samsung has been working on their own version of Apple's "force touch" or "force click".
    01-21-2017 04:14 PM
  2. amyf27's Avatar
    They would likely be on the bottom like the nexus 6p
    jamezr likes this.
    01-21-2017 08:18 PM
  3. jamezr's Avatar
    My thoughts too.... Hopefully they can be switched around as well.
    amyf27 likes this.
    01-22-2017 09:22 AM
  4. chyeo1979's Avatar
    Thought it will just be soft buttons like many other Android phones? Still can come out with other tricks?
    01-23-2017 02:39 AM
  5. Travis Bakker's Avatar
    I would probably guess at the buttons being software generated at the bottom as in many current devices. However it would be interesting if they introduced some gesture controls that could be customized.
    zoomis likes this.
    01-24-2017 02:52 PM
  6. Nakrohtap's Avatar
    I thought I read an article last week about the navigation buttons being customizable. Too lazy to search at the moment.
    Found it. Here's a snippet from a 9to5google.com article from a few weeks ago...
    https://www.google.com/amp/s/9to5goo...hms-tmobile-us
    01-27-2017 06:28 AM
  7. Travis Bakker's Avatar
    https://uploads.tapatalk-cdn.com/201...3158f6abaa.jpg
    Let's hope this holds true!
    01-27-2017 11:53 AM
  8. Nakrohtap's Avatar
    I would hope the buttons could be themed, as well as change color, brightness and maybe do some image shifting to prevent burn in. Seeing as the navigation buttons on the current phones only light up when you touch them, I would think it should be possible to hide software buttons as well.
    01-28-2017 09:32 AM
  9. Orion78's Avatar
    Yeah it would be awesome if the buttons are customizable.
    01-28-2017 05:16 PM
  10. EnemiesInTheEnd's Avatar
    My understanding is that the display ratio will be slightly longer than usual so the buttons on the bottom don't take up screen space like on other phones.
    Shelacios likes this.
    01-28-2017 07:21 PM
  11. Jaycemiskel's Avatar
    Well it'll still take up screen space, it's just they're accounting for that and making the screen larger.
    01-29-2017 07:48 PM
  12. Carrtman's Avatar
    If the pressure click or whatever they call it rumors are true it might be something weird.
    Maybe 1 soft click is home button, harder one recent apps and fully pressing it back button boy that would be stupid
    01-30-2017 06:12 PM
  13. Jaycemiskel's Avatar
    I'm sure they'll have the 3 separate ones. Probably have extra functions on them depending on how hard you press.
    01-30-2017 07:11 PM
  14. Carrtman's Avatar
    which under pressure would fail thats why I prefer physical off screen buttons
    02-01-2017 06:08 AM
  15. Jaycemiskel's Avatar
    I prefer off screen too. As long as the basic functions work, I guess I'll be OK. I don't see force touch being helpful or something I'll use. I think Samsung was the only big manufacturer left using physical buttons anymore though so we're just SOL.
    02-01-2017 07:21 AM
  16. SilentByte's Avatar
    This would be awesome if true. Like a resolution that's 48 pixels taller than normal. Somehow I doubt it though, because that would be an odd screen size to manufacture. I really hate on screen buttons. Wasted space plus major burn in on AMOLED devices.
    02-23-2017 10:30 PM
  17. flyingkytez's Avatar
    I hope nav buttons aren't going to get burned in. They should definitely have an auto hide mode to hide the nav buttons. But then again, the time display and battery icon doesn't move either, so I don't think it'll matter. People buy new phones every 2 years, and the AMOLED display should easily hold up fine with normal use.
    02-24-2017 10:14 AM
  18. Almeuit's Avatar
    Yep.
    02-24-2017 10:28 AM
  1. the recent apps opened button won't work
    Last Post: 01-31-2017, 12:53 PM
  2. Importing data*to S Health
    By BlackSheriff84 in forum Ask a Question
    Last Post: 01-23-2017, 03:39 AM
  3. Replies: 2
    Last Post: 01-21-2017, 10:42 PM
  4. Replies: 2
    Last Post: 01-21-2017, 09:54 PM
  5. Android OS across devices - smart TVs too?
    By CompuDino in forum Ask a Question
    Last Post: 01-21-2017, 03:33 PM
