1. datum9's Avatar
    Can one easily take out the battery and replace it?
    Or will it be one of those non-user replaceable batteries?
    01-27-2017 10:09 AM
  2. SpookDroid's Avatar
    If the past designs are any indication and the latest leak is true, then I'd go with 'not easily replaceable' (definitely not removable).
    Here's our first live look at the Galaxy S8 | Android Central
    01-27-2017 11:41 AM
  3. datum9's Avatar
    I won't buy any device without the ability to remove the bullshyte stock 3,000+ mAh cell and install an high-capacity ZeroLemon 10,000 mAh cell.
    Not a 2560x1440 screen with increased power consumption
    02-12-2017 11:29 AM
  4. jamezr's Avatar
    You might be stuck just buying the V20 or maybe the Note 4?
    02-12-2017 12:17 PM
  5. Jaycemiskel's Avatar
    You won't be getting a Samsung, LG, or HTC flagship. Nobody is doing those anymore.
    02-12-2017 12:56 PM
  6. jasonandrews25788's Avatar
    I want to add that the non-removable battery design is a must these days to make the phone thinner as possible.
    02-20-2017 12:47 PM
  7. Mike Dee's Avatar
    The V20 is pretty thin and removable.
    02-20-2017 01:28 PM
  1. Chinese Smartphones and Battery Life?
    Last Post: 02-01-2017, 10:54 AM
  2. Replies: 1
    Last Post: 01-27-2017, 02:01 AM
  3. Replies: 2
    Last Post: 01-26-2017, 05:58 PM
  4. Replies: 1
    Last Post: 01-26-2017, 05:15 PM
  5. Replies: 1
    Last Post: 01-26-2017, 11:05 AM
