1. James Falconer's Avatar
    Any guesses on official battery life specs for the S8 Plus? I know the previous Notes have had some decent life (no Note 7 jokes please) :P. Just wondering what we might be able to expect from the Plus!! Kind of excited
    02-10-2017 08:44 AM
  2. Aquila's Avatar
    My best guess is 4-5 hours of SOT across 18-30 hours of usage, 7 hours SOT for those that burn through it in 12-15 hours.
    02-10-2017 08:50 AM
  3. James Falconer's Avatar
    You're probably right. Would love something that got me through 1.5/2 days with ease. Will see.
    02-10-2017 08:53 AM
  4. wolfedude88's Avatar
    I haven't used an android phone in a while but my 7 or 7 plus couldn't make it through the day without charging it once before bed.
    That's all I ask for, no matter the usage it should make it at least from 5am until at least 11am with super heavy usage. No phone has come close. My phone is off the charger at 5am and by 1 pm I'm at less than 10%. It's not horrible to have to charge it once but I just want a phone with all day battery life.
    02-10-2017 09:10 AM
  5. James Falconer's Avatar
    Wow that's crazy. You must be a super power user!!! Do you carry cables, battery packs or charging cases with you to make it through the day?
    02-10-2017 09:12 AM
  6. wolfedude88's Avatar
    I don't even consider myself a power user. I listen to audible but even before that I could never get a phone to last. Just getting on Facebook for a few minutes, internet mostly just browsing.
    02-10-2017 10:38 AM
  7. James Falconer's Avatar
    Crazy. Stinks that the battery is letting you down.
    02-10-2017 11:28 AM
  8. ol_jackburton's Avatar
    I know this is not a good comparison, but my Note 7 would last me all day on a single charge (5am to about 9pm). I would say moderate usage, i listen to pod-cast a good part of the day.
    03-07-2017 11:29 AM
  9. Matty's Avatar
    I'm going to say, if it comes with a 3,500mAh battery then it might be rated as "Up to 15 hours" Video Play Time. Maybe using a 3G connection and browsing the web you could get "Up to 10 hours". The values I'm getting here is by using the Galaxy S7 as a benchmark and taking into account the larger display but also a more effect processor.
    I think most people will be happy if the device can last the whole day with 5+ SOT. I do predict the battery life will be lower than the S7 Edge but not too much.
    03-17-2017 06:29 AM
  10. Viscomi4444's Avatar
    Not only is the 835 processor going to make the battery life significantly better but the Samsungs new display will supposedly drain less battery life as well. Combine those two with a 3,500 battery and a less intrusive grace UX, the battery life should be better than the note7.
    03-18-2017 10:09 PM
  11. Wizzy's Avatar
    Based on my S7 edge, with that large screen, I'll predict 5 hrs SOT to start, decreasing to 3-4 hrs with updates.
    03-25-2017 04:30 PM
  12. Storm24's Avatar
    I can usually get a day out of my S7E unless some rogue app went on a rampage and did the battery drain after an update. I hope the 835 makes more things like playing music and streaming more fuel efficient so that we can stretch it as long as possible...
    03-25-2017 07:23 PM
  13. jacko147's Avatar
    I haven't heard what size battery yet, what's the rumours?
    kayleeskyesingh22 likes this.
    03-27-2017 10:39 AM
  14. EMGSM's Avatar
    At the very least, this is what we are all hoping for. I have high hopes for the 10-nanometer technology of the 835.
    03-28-2017 12:08 AM
  15. boxa72's Avatar
    I've heard anywhere between 3500 and 4000. Anything less than 3600 is ridiculous on a phone that size but having said that I'm happy with my 6P so probably won't be buying in.
    03-28-2017 12:46 AM
  16. jacko147's Avatar
    I'm thinking they're going to be cautious with regards to the n7 debacle
    03-28-2017 10:52 AM
  17. linda360's Avatar
    Use any of eyes protection apps for low light. I think then it will go for 6 or hours.
    03-28-2017 12:51 PM
  18. Wizzy's Avatar
    Huh?
    03-28-2017 06:21 PM
  19. digitalbreak's Avatar
    I tend to see if the battery lasts my work hours + evening time, typically from 8am till 7pm. S7 Edge cruised along this and I am sure S8+ will do so as well.
    03-29-2017 11:31 AM
  20. billyatynan's Avatar
    With a great screen I hope battery life will not be affected too much. Come on Samsung.....
    03-29-2017 04:15 PM
  21. Haggar's Avatar
    I saw the following battery life chart on a couple of different sites. I screen grabbed this one from CNET:
    03-29-2017 04:22 PM
  22. Haggar's Avatar
    I should note - those are numbers provided by Samsung - not numbers from any 3rd party tests/sites.
    03-29-2017 04:23 PM
  23. Bautiprea's Avatar
    Hello, new to the forum. I received the s8 plus 2 days ago, Im on vacations so Im using airplane mode only wifi. I was expecting S7 edge or better battery life but unfortunately its not the case.(I hsve the exynos which is supposed to have better bsttery life than the Snapdragon).My sot the first day(after emptying first chsrge and charging fully through the night) was 4.5hs with location, wifi, airplane mode, wqhd and brightness at around 1/3. I should say that Im a heavy Snapchatter in the most part, and then instagram and whatsapp. It may be Snapchat that drains my battery because Im being pretty easy on the phone right now. Today(second day) I set it to Fhd, airplane mode, wifi, and location, used some spotify, phone under heavy sunlight so full brightness there, lots of Snapchat and its 10pm with 17% abd 3.15 sot. It may seem ok to you to be with 17% by this time, but when I got my s7e, the first days I litteraly had to drain the battery, I would get on average 6 30 to 6 hs sot, not to say that the battery went terrible on my s7e.So yeah, Im a bit concerned with the s8p, any suggestions?Is it Snapchat that drains my battery?
    07-15-2017 09:05 PM
  1. Life after 6P...whats next?
    By chezm in forum Nexus 6P
    Last Post: 04-25-2017, 09:54 PM
  2. Replies: 2
    Last Post: 02-14-2017, 04:10 AM
  3. Moto X pure, heating and battery
    By AC Question in forum Moto X Pure Edition
    Last Post: 02-10-2017, 11:09 AM
  4. HTC M8 - Battery wont charge after replacement
    Last Post: 02-10-2017, 03:59 AM
  5. Moto X pure, heating and battery
    Last Post: 02-09-2017, 10:40 PM
