Re: Samsung Galaxy S8+ Specs: UHS-I or UHS-II microsd card slot "bus" type?
[FONT=verdana, sans-serif]S8+: is there a way to find out if this phone has a MicroSD card slot that uses UHS-I or UHS-II "bus"? I can't seem to find this information anywhere.
[/FONT]
[FONT=verdana, sans-serif]UHS-I = single row of contacts (slower max speed); UHS-II = two rows of contacts (faster max speed)[/FONT]
[/FONT]
[FONT=verdana, sans-serif]Kindly please note that this is NOT the UHS3 (the number 3 inside a letter U). this UHS-I or UHS-II has to do with the "bus" that is reading the micro sd card and also the micro sd card itself: the UHS-I cards have only one row of contacts, while the UHS-II cards have two rows for much higher read/write speeds.
[/FONT]
[FONT=verdana, sans-serif]No where was i able to find this information!
[/FONT]
[FONT=verdana, sans-serif]Thanks in advance.[/FONT]
