Default resolution on the S8 phones is full HD+ out of the box... 1080p... not set to the amazing looking Quad HD+ 2960x1440.
I know the S7 had resolution change ability too right? But I thought they defaulted at Quad HD and still had great battery life. But I did read when Nougat update was available, the update changed the default resolution to 1080p. So people that noticed a little more battery life after Nougat... well ya if you brung down the resolution to 1080p that might help.
Not sure how to think about that default of 1080p... most likely to save battery life since they will be rocking 3000 mah and 3500 mah batteries. But isn't it kinda cheaty? Doesn't it defeat the purpose of having the spec if it's not set at default? Most likely people won't even notice the difference or ever realize they are running 1080p.
If you buy an S8... are you going to run it at 1080p or are you going to run it at its full glory?
When we start reading reviews... are they going to mention if they ran battery tests with screen at default 1080. Or at Quad HD?
Just some thoughts I had while waiting on full reviews and battery is going to be important to me.
