1. hparsons's Avatar
    We have the Qi-Infinity Fast Wireless Car Charger Dock in both our cars for our current Note 5 phones (my wife and I each have one). To charge the Note 5 in our case, the "arms" that hold the phones have to be the bottom-most setting.
    Anyone know if the S8 Plus would fit in the charger/dock? Or if not, the actual dimensions of the phone (as opposed the screen size)?
    I know that the screen size of the 8 Plus will be 6.2" (The Note 5 is 5.7") but because of the difference in the bezel configuration, that doesn't tell me how much bigger/smaller it would be.
    03-31-2017 05:09 PM
  2. durandetto's Avatar
    I believe the s8+ will be narrower than the note 5.
    04-02-2017 12:31 PM
  3. hparsons's Avatar
    Narrower won't be a problem on the charger, as the side clamps are adjustible and have a lot of travel. I'm concerned that the arm foot vertical adjustment may be too short.
    04-03-2017 01:55 AM
  4. ClintRo's Avatar
    It is taller, but it should still work, hard to say without testing... you could always remove the charging dock take it into a Best Buy or Verizon store and see if it charges. If they won't let you use one of their chargers, just take a battery pack. If they think you are interested in buying I am sure they will let you test it.
    04-03-2017 08:40 AM
  5. hparsons's Avatar
    Good idea, but I went ahead and ordered the S8+. If it doesn't quite line up, I'll see if the dock's arms can be modified. If not, I'll start shopping around...
    04-04-2017 02:15 PM
  6. hparsons's Avatar
    Tried out out today, and it worked great.
    the_munc_e likes this.
    04-23-2017 12:49 AM
  7. ClintRo's Avatar
    Sorry..... For some reason I looked for this thread on Friday and couldn't find it. Worked for me as well.
    04-23-2017 08:56 AM
  8. the_munc_e's Avatar
    Anyone got a link to the charger? I'd like to get one.
    04-25-2017 01:32 PM
  9. karmajack's Avatar
    https://www.amazon.com/Qi-Infinity-Wireless-Charger-Compatible-Qi-Enabled/dp/B018INZ10O
    04-25-2017 08:25 PM
  10. rblee83's Avatar
    This is what I'm getting when it comes out in May, it looks PERFECT: https://www.iottie.com/Product/Detai...etic-Car-Mount
    NokiaBeast likes this.
    04-27-2017 07:44 PM
  11. karmajack's Avatar
    They've got the right idea with the plate design. However, I don't like how it mounts to the car, nor how bulky it is. Also that MSRP. Hopefully a competitor takes not of the charging and magnetic design and offers alternatives though.
    04-29-2017 02:26 AM
  1. Replies: 17
    Last Post: 09-18-2019, 01:49 AM
  2. car charger
    By nonie in forum Samsung Galaxy S8 & S8+
    Last Post: 08-17-2017, 05:11 AM
  3. Lg ls740 capacity sd car??
    Last Post: 03-31-2017, 08:16 AM
  4. Can i charge my samsung prime with a wireless charger
    Last Post: 03-31-2017, 07:35 AM
  5. Can i charge my samsung prime with a wireless charger
    Last Post: 03-31-2017, 07:34 AM
