CKwik240
The S8 is the same width as the S7. Feels a bit smaller in hand, perhaps due to the curved screen. I actually prefer it.
I am sure over time it will become more natural, just feel placing it in the middle of the back would have been much easier to reach and get used to.
And the answer is that there won't be a single figure that you can use for comparison. It will depend on whether you care more about the width or the area of the display - for the same diagonal both depend on the aspect ratio, but the width changes a bit faster.
A little bit of trigonometry says that if we define the aspect ratio as R:1 (length:width), then
width = diagonal/sqrt(1+R^2)
area = diagonal^2*R/(1+R^2)
Values of R would be:
16:9 = 1.778
2:1 = 2 (obviously)
18.5:9 = 2.056
So if we unroll the curved edges the S8's 18.5:9 screen has 89% of the width of a 16:9 of the same diagonal dimension, and 92% of the area. Because the width depends linearly on the diagonal and the area quadratically this means it has the area of a 5.6" 16:9 screen and the width of a 5.2" one (rounding both to 0.1"). However, the curved edges make comparing the widths this way impossible, since how much they change the width by will depend on the shape of the curve, which varies between models.
The feel in hand of the S8 is just superb. And I have a S7 edge that I am beginning to like more and more each day. Although the narrow screen does feel like I am being cheated a bit when watching videos. The S8+ was not available to preview because the security holder had issues and was being fixed. I will try to go and check the S8+ out today.
Screen feels narrow.What did you mean that you felt you were being cheated with videos is it because of the black bars at the end or is the screen too narrow?
The S8 does seem too narrow for me too. Definitely depends on your preferences. It may be perfect for some peopleScreen feels narrow.
Don't get me wrong, I really like it and am probably going to get one.The S8 does seem too narrow for me too. Definitely depends on your preferences. It may be perfect for some people
Yes I agree. S8 Plus is rather close to the Note 7. The S8 is similar to the 7Edge. Its just too skinny for me so Ive got the Plus on orderTHE s7edge smaller by a long shot. i own one, and specs on note 7 are relative to s8plus.
What if you're playing a game or something and hit the spot on the screen where the home button is and you leave the app on accident?
Up to a point. The advertising is factually correct, but as many people won't appreciate the difference that the aspect ratio makes then just quoting it without any explanation or qualification creates an impression that's a little different from reality.If someone tries to take diagonal length and assumes display area should go up by the same percentage amount, that person will draw the wrong conclusion. It is not because the advertising is misleading, it is because that person doesn't understand the difference between diagonal length and display area.
Of course the numbers don't matter: anyone looking at the device can see the size of the screen and that's what is actually important. But marketing likes numbers.
