08-31-2018 01:04 PM
149 ... 3456
tools
  1. Snareman's Avatar
    Update: it appears to be QC 3.0. I got my S8+ today and have been playing around with various combinations of cables and chargers. For example, I have this one from Anker that has 2 ports, one 2.0 and one 3.0: https://www.anker.com/products/A2224011 . With the right cable (and some ones I got from Monoprice are not the right cable!) I get "fast charging" displaying on my phone only when I plug the phone into the 3.0 port. It just reports "charging" when plugging into the 2.0 port. And it says "slow charging" when plugging into a charger not marked for Quick Charge.
    Does it show a difference in what the total charging time will be when you think it is qc3 versus 2 versus neither?
    04-20-2017 08:12 PM
  2. Rumline's Avatar
    Download Ampere and check the current/voltage. Then you can tell for sure. Maybe.
    04-20-2017 08:18 PM
  3. louisdimeglio's Avatar
    When connected to a QC3.0 charger with the included Samsung cable and the battery at 40%, the S8 is drawing 1A but I haven't found an app that shows the voltage it is drawing so for all I know it is drawing 18V at 1A, which would be QC3, or 1A at 5V which wouldn't even be QC1. That being said, it read 1h 4min to full from 40%.
    04-22-2017 02:06 PM
  4. Snareman's Avatar
    When connected to a QC3.0 charger with the included Samsung cable and the battery at 40%, the S8 is drawing 1A but I haven't found an app that shows the voltage it is drawing so for all I know it is drawing 18V at 1A, which would be QC3, or 1A at 5V which wouldn't even be QC1. That being said, it should 1h 4min to full from 40%.
    And how long to full with the stock charger in comparison?
    04-22-2017 02:08 PM
  5. louisdimeglio's Avatar
    Well, with the battery at 40%, exactly the same amount of time.
    I also tried a QC2.0 charger, and the time was again, exactly the same.
    In all cases the screen showed "fast charging"
    Edited to add: I have a USB-C pass-thru power monitor coming from Amazon on Sunday. I'll take all the measurements then.
    blaine07 likes this.
    04-22-2017 02:15 PM
  6. louisdimeglio's Avatar
    Just a note the stock charger reads:
    OUTPUT: 5V @ 2A or 9V @ 1.67A
    So it appears with the stock charger it can charge at up to 15W.
    Since the QC2/3 max current is 18W (and 4 is 28W) this is firmly in the QC2/3 territory. At least it is better than the 10W max of QC1.
    04-22-2017 05:36 PM
  7. Kirk Maluo's Avatar
    That's what I thought too.
    You gotta remember that a year old S7 is going to have maybe 80 percent or less of the rated capacity left, so of course it's going to charge faster. I have an old Note 4 battery that can go 0 to 100% in 15 minutes.
    04-22-2017 07:09 PM
  8. Jaycemiskel's Avatar
    Quick charge 3.0 is backwards compatible. So it's probably just utilizing 2.0. I have both QC 2 and 3 charges and there's no difference in the charging speeds that I've noticed. Unfortunately they didn't upgrade the charging speed this year.
    04-22-2017 07:13 PM
  9. louisdimeglio's Avatar
    Precisely.
    04-22-2017 08:11 PM
  10. Snareman's Avatar
    ... Unfortunately they didn't upgrade the charging speed this year.
    Or last year...
    04-23-2017 03:15 AM
  11. Jaycemiskel's Avatar
    Or last year...
    Lol yeah that too.
    So I had a weird experience with my computer. Plugged in a USB C to USB C cable and it said it was fast charging. Anyone else had this experience?
    04-23-2017 01:14 PM
  12. louisdimeglio's Avatar
    It seems to me that anytime it can grab over 1A@5V the S8 is reporting quick charging. I'll do some analysis late tonight and post the results.
    04-23-2017 02:05 PM
  13. jeetu4444's Avatar
    I know for sure and many reviewers said s8 has qc 2 and G6 has QC 3
    Even my blu life one x2 has QC 3
    04-23-2017 04:16 PM
  14. louisdimeglio's Avatar
    OK.. Here's the analysis. Used an inline USB-C power meter. Based on this, it appears QC2 is still what's implemented:
    All tests performed with battery between 19-21%
    QC3.0 Charger: With Screen on -- Charging at 5V and 1.25A (6.25W)
    With Screen off -- Charging at 9V and 1.25A (11.25W)
    QC2.0 Charger: With Screen on -- Same as above
    OEM Included Charger: Same as above
    Non QC 2A Charger: Charges at 5V and 1.85A with screen on or off (9.25W)
    USB-PD Certified Charger: Charges at 5V and 2.5A with screen on or off (12.5W)
    Note that with the QC and Samsung charger, the moment the screen is activated, the voltage drops to 5V. When the screen idles back to the AOD, then the voltage goes back up to 9V.
    Also, a USB-PD power supply is going to give you the fastest charging time, interestingly enough.
    Once I get a chance, I'll do some longer testing since the meter also measures the total mAh pulled by the phone. I can do some timed tests from the same battery percentage to see how things go.
    Rumline, ClintRo and afh3 like this.
    04-23-2017 08:31 PM
  15. Rumline's Avatar
    Interesting that USB-PD gives such higher current. Did that make a difference in overall charge time?
    04-23-2017 08:37 PM
  16. louisdimeglio's Avatar
    I haven't gotten to do any extended testing. I will do that testing yet. I will try some testing taking the phone from 20-50% with the QC2, Samsung and USB-PD chargers. That'll take some time to do and I won't be able to do it until likely tomorrow some time.
    04-23-2017 08:55 PM
  17. Almeuit's Avatar
    It would say that no matter what because QC 3.0 are backwards compatible with QC 2.0 so it would say Fast Charging either way.
    04-23-2017 10:30 PM
  18. northward's Avatar
    I know that they're backward compatible. What I pointed out is that the phone only reports "Fast Charging" when connected to a QC 3.0 charger, and not to a QC 2.0 charger.
    04-23-2017 10:33 PM
  19. Almeuit's Avatar
    Interesting .. I will have to try it with my QC 2.0 brick when home and see what it shows.
    04-23-2017 10:35 PM
  20. louisdimeglio's Avatar
    This is not my experience. My phone reported fast charging connected to a QC3, QC2, USB-PD and even plain old 2A USB charger. The only time it didn't was when attached to a 1A or less charger.
    04-24-2017 07:33 AM
  21. ilordvader's Avatar
    If you want High Speed Transfer
    then make sure you get USB Type C wire with 3.1
    USB 3.1 vs. USB Type-C vs. USB 3.0 What’s the difference ?
    USB 3.1 - 10 Gbps
    USB 3.0. 5 Gbps.
    04-27-2017 12:26 AM
  22. beardedfool's Avatar
    Hi,
    I'm getting fast charging notification but Ampere doesn't read above 1040 (screen on). Has anyone got any results, and what they'd expect to get in an ideal world?
    Just wanted to note there's a post on the samsung forums on charging https://us.community.samsung.com/t5/...-p/98577#M2179
    Top of pg3 you can see a mod has added it to their tracker
    04-29-2017 08:51 AM
  23. razortaz18's Avatar
    Hi,
    I have tried 6 different chargers including the stock charger and can not pull over 1020 ma according to Ampere.
    04-29-2017 10:46 AM
  24. Highrisedrifter's Avatar
    So if I get a QC3.0 fast charging power block, it won't harm my phone if the phone is only QC2.0? Sorry for the noob question, new to this.
    04-29-2017 05:41 PM
  25. Rumline's Avatar
    I've seen 1950 ma on GSAM. Haven't tried Ampere.
    04-29-2017 05:55 PM
149 ... 3456
  1. Problem with new Tag 45 Modular (Charging)
    By Koromazoff in forum TAG Heuer Connected
    Last Post: 04-04-2017, 02:14 PM
  2. The Galaxy Note 7 has played a (negative) part in the S8
    By BlackZeppelin in forum Samsung Galaxy S8 & S8+
    Last Post: 04-03-2017, 05:11 AM
  3. what is android system webview on my android phone used for
    Last Post: 04-02-2017, 08:35 AM
  4. Replies: 1
    Last Post: 04-02-2017, 06:40 AM
  5. What does "network not registered" mean?
    Last Post: 04-02-2017, 05:54 AM
