Aquila
Retired Moderator
Re: Fingerprint sensor placement concerns? Wait till you read this.
Woo!Thank goodness buying it is strictly voluntary.
Apparently Samsung is aware of placement issue and the phone will warn you to clean the camera lens occasionally
That's a poor argument. 1. Gas and brake pedals are really easy to reach. 2. I could never accidentally press something else when I'm reaching for a pedal. 3. The seat can be adjusted to reach the pedals. You can't adjust the placement of the fingerprint sensor on the S8s.
Look, I think the S8s are beautiful phones, but even I admit the placement of the FPS is terrible. Nobody should be excusing it.
So I wasn't expecting to like it, but it's worse than I thought. It's almost flush with the back of the device, exactly like the camera. There is no way to "feel" for it. Almost indistinguishable from the camera horrible job Samsung.
2. I've driven only manual transmission my entire life. They're all slightly different. I've accidentally tapped the brake while pushing for the clutch. Recently had a cast on my foot and did this horribly. 3. The reach for the fingerprint sensor is adjustable much like your car seat slides forward you slide your hand up the phone.
My car is a manual and I've never had that issue. I mean, one stops the car and the other puts it in neutral.
If a phone has to have a popup warning you that the camera is too smudgy to use, maybe they should've rethought the FPS placement.
3 months in it will be a non issue. i am more wrapped up in weather i should leave the back button on the left or right.
What's going to suck is the Note 8 is right around the corner and will have the fingerprint sensor under the glass home button on the front. Everyone that buys the S8 will be regret their purchase once this comes out. :'(
After seeing this video I'm having second thoughts.
https://www.youtube.com/watch?v=0zqsqOMtzTs
WrongI agree, not a beautiful phone. Too long, made of glass, not enough bezels to hold it, curved corners weird me out. Maybe it'll grow on me, but for now it's a bag of blunders.
Wrong
I'm still baffled as to why they put it up there.
They were trying to get the reader under the screen, but Synaptics was unable to provide a workable solution in time. By that point, so much stuff had been engineered it was the only place that was feasible.
If Synaptics works it out in time, the fingerprint reader could be under the screen on the Note 8.
So how does a person wake a phone to use Iris scanner without touching the fingerprint sensor?
I don't plan on using it. Are you able to get the joke button on the lockscreen without using the fingerprint sensor.The iris scanner is not a good alternative for permanent use as you have to press the home button and then swipe on the screen to access it. Much to complicated.
