1. Frozen Corpse's Avatar
    05-30-2017 06:45 PM
  2. gendo667's Avatar
    Found a few good walls on an app called Blacker. Currently on the Play Stores front page. Way to many ads, uninstalled. I like what I found though.
    05-31-2017 08:20 AM
  3. bembol's Avatar
    Made some minor changes. Decided to use Dock and using Weather Live widget instead of my usual HD Widgets.
    gendo667 likes this.
    05-31-2017 10:14 AM
  4. al3azim's Avatar
    What's the clock and day of the week Widget called?
    it's my own KWGT widget creation.
    05-31-2017 11:14 AM
  5. Frozen Corpse's Avatar
    Darth Vader never gets old! ™
    amyf27 likes this.
    05-31-2017 11:38 AM
  6. Frozen Corpse's Avatar
    05-31-2017 12:00 PM
  7. swanny1981's Avatar
    My AOD. Go Cubs!
    Post homescreen screenshots taken on your Samsung S8 / S8+-cubs-aod.jpg
    05-31-2017 05:20 PM
  8. Jason Rak's Avatar
    Basically new to Android and having alot of fun Amazing what you can customize and multitask with.
    Attached Thumbnails Post homescreen screenshots taken on your Samsung S8 / S8+-screenshot_20170531-224639.jpg
    05-31-2017 10:50 PM
  9. anon(27512)'s Avatar
    Finally got the s8+ working normally.
    Attached Thumbnails Post homescreen screenshots taken on your Samsung S8 / S8+-187.jpg
    Frozen Corpse likes this.
    06-01-2017 01:32 AM
  10. anon(27512)'s Avatar
    Attached Thumbnails Post homescreen screenshots taken on your Samsung S8 / S8+-188.jpg
    06-01-2017 01:33 AM
  11. gendo667's Avatar
    Welcome to Android, and Android Central for that matter. And well done. Hope you're enjoying your experience.
    Jason Rak likes this.
    06-01-2017 04:37 AM
  12. Frozen Corpse's Avatar
    I love minimal setups...
    amyf27 likes this.
    06-01-2017 04:58 AM
  13. Frozen Corpse's Avatar
    I think I'm addicted to wallpapers.
    06-01-2017 09:30 AM
  14. gendo667's Avatar
    It's not just you. I'm always looking for something new.
    06-01-2017 09:34 AM
  15. djrakowski's Avatar
    Nice setup... and as far as addictions are concerned, wallpapers seem pretty safe
    06-01-2017 09:35 AM
  16. OneSick8350i's Avatar
    Long time since I was active. See username lol
    Grabbed an S8! Amazing!
    Attached Thumbnails Post homescreen screenshots taken on your Samsung S8 / S8+-screenshot_20170601-105114.jpg
    uncreativeartist likes this.
    06-01-2017 10:58 AM
  17. Zyrros's Avatar
    GIF ANIMATED VERSION
    Theme applied to galaxy s8 (18.5:9 aspect ratio)
    Nova launcher as base with dock disabled.
    Background and widget made in photoshop.
    Theme (everything seen in the gif) made in Kustom Live Wall paper.
    Icons are from the PipBoy White icon pack.
    Status bar and navigation bar (soft buttons) removed with Tiles app Inmersive Mode.
    As a note, the home screen itslef is completely empty without any real icons or widgets. All the theme is inside the the live wallpaper.
    The circular glass screen lightning effects moves trough the gyroscope, to try to simulate how it would react to light.
    The screen contents are interactive: Touching the hour opens the clock and alarms app, Touching date opens calendar, Touching the weather icon opens GoWeather, Touching the wi-fi information toggles the wi-fi connection. The external ring composed of dots that rotate shows battery left too.
    Touching the lower part of the screen/screen ring toggles GPS Maps mode, alternating between the first menu and a modified version of the MapsMaker komponent.
    It has a screen unlock animation in which the screen starts all black then fades into the background starting from the top, but couldnt record it since recorder doesnt record locked screen.
    The background image is separated in several layers, so that each layer is easily replaceable in both texture, color and transparency. Textures and colors are all easily manageable from the same menu trough global variables. External backgrounds can be set up too.
    06-01-2017 11:12 AM
  18. LetMeKnowIf's Avatar
    As minimal as possible :-)
    06-01-2017 11:43 AM
  19. Frozen Corpse's Avatar
    I totally agree!
    06-01-2017 01:07 PM
  20. Frozen Corpse's Avatar
    http://i.imgur.com/kmQ6Lya.jpg
    awesome!
    06-01-2017 01:12 PM
  21. Frozen Corpse's Avatar
    robmidi and uncreativeartist like this.
    06-01-2017 01:17 PM
  22. Frozen Corpse's Avatar
    06-01-2017 01:19 PM
  23. Frozen Corpse's Avatar
    Pretty good looking.... ®
    06-02-2017 08:40 AM
  24. robmidi's Avatar
    They're here!
    06-02-2017 06:48 PM
  25. uncreativeartist's Avatar
    I want something like this so bad but don't have the money or the know how to get it done. I actually liked your other one a little better, it had all the notification bar stuff on the main screen, very cool. Great job!
    06-02-2017 10:17 PM
1,182 ... 2324252627 ...
  1. Screen On!
    By TomAd9 in forum Samsung Galaxy Note 5
    Last Post: 05-02-2017, 08:56 AM
  2. Low volume issue with Samsung S7 Edge?
    By markm75 in forum Samsung Galaxy S7
    Last Post: 04-24-2017, 11:05 AM
  3. Replies: 1
    Last Post: 04-18-2017, 03:56 PM
  4. Screenshots during setup?
    By Gary02468 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-18-2017, 03:16 PM
