gendo667
Trusted Member
How do you do it?Just found out that with nova launcher you can use image from gallery as icon. So I've been downloading image from Google and changing each icon to somehow make it 3D. //uploads.tapatalk-cdn.com/20170809/672b63f3f5606eea163e682ba95229d2.jpg
I like it!Just found out that with nova launcher you can use image from gallery as icon. So I've been downloading image from Google and changing each icon to somehow make it 3D. //uploads.tapatalk-cdn.com/20170809/672b63f3f5606eea163e682ba95229d2.jpg
How do you do it?
ThanksIn novas icon edit. Select gallery apps. Then use a gallery app you like and select the downloaded image you like.
Also to create transparent image use eraser app from play store
https://forums.androidcentral.com/e...com.handycloset.android.eraser&token=6krIIseT
//uploads.tapatalk-cdn.com/20170817/8c8fbfd7331dd8f9a7b8dbc350106a78.gif
Weird. My avatar matches your theme.
