04-23-2017 05:05 PM
36 12
tools
  1. thehoz's Avatar
    Hi,
    I am interested in getting one of the wireless chargers for the s8 plus. Is anyone able to tell me the difference between the new wireless charger that costs $90 on the Samsung website compared to the older one that is $60. They are both fast charging apparently. Is the only difference the looks and convertibility of the new one? Or, is the new one better for the s8?
    Thank you.
    04-20-2017 08:09 AM
  2. prissysox's Avatar
    Hi,
    Thank you.
    Both will work just fine. This year's model is convertible and much bigger. If you want smaller and don't care about convertibility save the money and go for last year's model.
    thehoz likes this.
    04-20-2017 08:39 AM
  3. Nakrohtap's Avatar
    ...or, you can save even more money and get one off of Amazon for around $20. There are a lot of options out there.
    thehoz and Mr_Spencer like this.
    04-20-2017 09:06 AM
  4. Ecm's Avatar
    Hi,
    Thank you.
    Last year's Samsung wireless chargers support fast charge for recent Samsung devices (most 3rd party do not) and are available as a pad or stand. The new one does everything that last years does, plus it folds from a stand to a pad and is a little funkier-looking -- as well as being more expensive. They will function the same.
    thehoz likes this.
    04-20-2017 10:05 AM
  5. robber's Avatar
    There are good deals on Amazon as stated above, just be sure to buy a Samsung product as wireless fast charging is proprietary to Samsung.
    thehoz likes this.
    04-20-2017 10:10 AM
  6. rhsortho's Avatar
    I believe the new Samsung one, besides being convertible also has a built in fan.
    thehoz likes this.
    04-20-2017 10:19 AM
  7. Ecm's Avatar
    Last year's versions also have the fan.
    thehoz likes this.
    04-20-2017 10:21 AM
  8. Nakrohtap's Avatar
    I think you just need to have a charger compatible with Samsung, not Samsung branded.
    Samsung uses universal charging technologies in the S8 (Wireless Charging compatible with WPC and PMA) which is compatible with almost all wireless chargers.
    For fast charging, you get a fast charge wireless charger and you use the charging block and cable that comes with your phone.
    I bought one with my Note7 and used it with my S7E. It worked fine for both.
    thehoz likes this.
    04-20-2017 10:23 AM
  9. rhsortho's Avatar
    ahh good to know. thanks! i'll have to look for last year's one I'm still using the rectangle Note 3 one from Samsung.
    04-20-2017 10:27 AM
  10. daddyd302's Avatar
    Just get something like this and call it a day. No need to pay Samsung $40+ for something that others offer for way cheaper.
    https://smile.amazon.com/dp/B01M0IL0QX?psc=1
    thehoz likes this.
    04-20-2017 10:32 AM
  11. omgitselaine's Avatar
    I never knew how much I miss wireless charging until now.
    I've had a LG V20 since turning in my Note 7 and it's such a convenience to simply place the S8+ on my chargers.
    I have a few all over in my home
    04-20-2017 10:33 AM
  12. Ecm's Avatar
    Here you go. It's quiet, as well.
    04-20-2017 10:40 AM
  13. daveolej's Avatar
    Is anyone having issues with wireless charging? I have the one posted above. Fast Charge charger that works with the s7e but it keeps pausing every second. It is not charging the S8+. Tried without my case as well, same issue.
    04-20-2017 11:02 AM
  14. cert15z's Avatar
    Hi,
    Thank you.
    I am using this one. Fast charging works great.
    CHOETECH Fast Wireless Charger, Qi Wireless Charging Stand for Galaxy Note 5 / S8/S8 Plus /S7 / S7 Edge / S6 Edge+ and Other Qi-enabled Devices https://www.amazon.com/dp/B010B6PSMC...cUvbUpU5771548
    thehoz likes this.
    04-20-2017 11:13 AM
  15. BIG CAT 7's Avatar
    CHOETECH Fast Wireless Charger, Qi Wireless Charging Stand for Galaxy Note 5 / S8/S8 Plus /S7 / S7 Edge / S6 Edge+ and Other Qi-enabled Devices https://www.amazon.com/dp/B010B6PSMC...cUvbUpU5771654
    Bought that one myself. It is money......
    04-20-2017 11:43 AM
  16. durandetto's Avatar
    I have the Choetech one too, but it won't fast charge in portrait with my iBlaison armor box case on. Haven't tried it with my other case or naked yet. However the Samsung charging stand from last year works just fine. The problem with the Samsung stand from last year is it's too short and the phone feels really unstable on portrait mode.
    04-20-2017 12:38 PM
  17. Snareman's Avatar
    I have that problem with my S7E and its ungodly frustrating. I'm going to be pretty darn pissed if I also have it with my S8+.
    04-20-2017 01:51 PM
  18. Snareman's Avatar
    One of my annoyances with the Samsung charger is that the lip at the bottom is really small. I have a Tyle one that is nice and easy to plop the phone onto. I have to be much more precise putting it on the Samsung one.
    04-20-2017 01:53 PM
  19. omgitselaine's Avatar
    I have the TYTL ones also...... actually a few around the house in different colors of course
    This was my initial charge up last night.
    Ca_lvn and prissysox like this.
    04-20-2017 02:04 PM
  20. Ca_lvn's Avatar
    Tylt is always my 1st go too and the angle it holds the phone at is fantastic
    04-20-2017 02:31 PM
  21. felloffthetruck's Avatar
    https://uploads.tapatalk-cdn.com/201...e88ac300dc.jpg
    Is the TYLT slow at charging the S8? I have the green one somewhere that I can't find.
    04-22-2017 03:30 PM
  22. bhatech's Avatar
    I like the last year's Samsung fast wireless charger, there are always deals on them @ Amazon. If it's ships and sold from Amazon listing, you can even have best buy price match them and pick them up at your local store.
    jerseygirl likes this.
    04-22-2017 03:48 PM
  23. Snareman's Avatar
    Yes. Slow charging. I just use it at night next to my bed where it doesn't need to charge fast.
    felloffthetruck likes this.
    04-22-2017 04:01 PM
  24. omgitselaine's Avatar
    I do the same and I often don't really need fast wireless charging anyways.
    I often carry a power bank with me so I'm constantly charging and am rarely ever below 50%
    Just came back from the mall and I'm above 90% ........ the convenience of owning and using a handbag haaaaaaa !!
    blemoon42 and felloffthetruck like this.
    04-22-2017 04:32 PM
  25. Snareman's Avatar
    And an ///M.
    04-22-2017 05:34 PM
36 12
  1. Samsing Tab S power saving mode question
    By kk99ll in forum Samsung Galaxy Tab S 8.4
    Last Post: 04-25-2017, 12:50 AM
  2. Samsung s8 black colour question
    By mango1228 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-20-2017, 08:56 AM
  3. Questions about the S8 coming from an S6 user
    By justnivek in forum Samsung Galaxy S8 & S8+
    Last Post: 04-19-2017, 02:13 PM
  4. Replies: 1
    Last Post: 04-19-2017, 02:03 PM
  5. What's the difference between a fast charger and a normal one
    Last Post: 04-19-2017, 01:47 PM
