1. racedog's Avatar
    I would like to hear some feedback from those using and how it seems to be affecting their battery life. Did you use the phone before turning on aod, and if so, how much difference in sot and total battery life. And , yes, I know it's very early to know but we can start comparing experiences as we get more time in with our new phones.
    I guess we should also add what phone we have as that will make a big difference. I will turn on aod tomorrow morning when I take the phone off the charger.
    I'll be using an s8.
    04-20-2017 06:47 PM
  2. Almeuit's Avatar
    I have had a lot of people use AoD and they swear it doesn't mess with battery much at all. The reason due to this is because it only lights up the pixels it needs versus firing up the whole screen just to display it.
    Viscomi4444 likes this.
    04-20-2017 06:53 PM
  3. theelite1x87's Avatar
    I disabled the infinity wallpaper thing. In my opinion, it was too many lit pixels for my AoD . Now it's just clock and notifications. Also disabled home button marker. It still works , I don't need it to remind me where the home button is. Seems to have negligible impact on battery
    04-20-2017 07:05 PM
  4. Byoung23's Avatar
    I like the infinity wallpapers, but I too changed from it. I want to see some data/testimony on how it impacts battery life. If it proves negligible, I might switch to it, though I'm growing fond of the wallpapers I've been rotating.
    04-21-2017 09:54 PM
  5. Wizzy's Avatar
    On the S7 edge, it consumed about .5% per hour of battery life. I did tests with and without the AOD on. It probably wouldn't be much different with the S8. If I ever get my S8+, I'll test it again.
    04-21-2017 10:22 PM
  6. bassplayrguy's Avatar
    With aod on. I thought out got great battery life.
    04-21-2017 11:36 PM
  7. bassplayrguy's Avatar
    04-21-2017 11:36 PM
  8. EMGSM's Avatar
    Just like I said yesterday I could hit the 5 hr mark on my S8 and I did just that on day 2.
    04-22-2017 12:32 AM
  9. sergysn's Avatar
    Battery life is great on my s8+, much better than on my s6 edge plus.
    04-22-2017 03:31 AM
  10. bandofbrothers2112's Avatar
    Most probably because the s6 edge + has a Non-removable Li-Ion 3000 mAh battery.
    And the s8+ has a Non-removable Li-Ion 3500 mAh battery and a better optimised chipset.
    And as your new s8+ won't be full information and data , redundant files etc which we all naturally pick up along the away.
    04-22-2017 03:48 AM
  11. lowboydrvr's Avatar
    I am experiencing the same results. Much more impressed with the battery life of the S8+ compared to the S6E+.
    04-22-2017 04:30 AM
  12. thecaringkind's Avatar
    It's a nice feature but I don't use it. I value my battery conservation. It's informational value isn't worth even a minimal power drain.
    04-22-2017 04:51 AM
  1. Quick Memo+ and Battery
    By Jeremiah Bonds in forum LG G6
    Last Post: 05-29-2017, 12:20 PM
  2. Replies: 1
    Last Post: 04-20-2017, 06:49 PM
  3. Sprint Customer here. Trying to activate my new S8 and failing to activate
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-20-2017, 06:22 PM
  4. Replies: 0
    Last Post: 04-20-2017, 04:47 PM
  5. Coming from an iPhone? 150+ S8/+ tips and tricks in an hour long video
    By Highrisedrifter in forum Samsung Galaxy S8 & S8+
    Last Post: 04-20-2017, 04:42 PM
