tboy2000
Sorry do I need the 2016 USB C adaptor or the deeper 2017 USB C adapter for the S8 (non plus version)? I have the 2016 Gear VR.
The regular S8 will fit in the 2016 Gear Vr using the 2016 USB C adapter.Sorry do I need the 2016 USB C adaptor or the deeper 2017 USB C adapter for the S8 (non plus version)? I have the 2016 Gear VR.
Not sure what you mean by it doesn't fit in the 2016 Gear VR. I have one and use it with the S8+ and 2017 USB C Gear VR adapter just fine. Check my picture above.The S8 & S8+ absolutely will NOT work with the 2016 Gear VR UNLESS for some reason the goggles came with the "C" type connector! You can't put a square peg into a round hole(snuggly)! This is why people are breaking phones. I purchased the 2016 VR's with my S7. Worked great! Upgraded to the S8 & because of the "C" type connector it won't fit! I bought the "GH98-40350A" C-type adapter but can't connect it! It seems that wires need to be cut & soldered on. I'm looking for a video if anyone knows of such a video please let me know. Samsung support says it's not compatible. But I don't put much faith in their knowledge! If your VR's came with both adaptors consider yourself lucky. Don't waste the $ like I did on the "C" type until YouTube has a video on it! Good luck all!
That is because Samsung used the same model for both the Note 7 (USB C) and the S7 series (Micro USB)...doesn't look like they changed their mind. The one's received with Note 7 and after its released included both the adapters in the box.I think Samsung was manufacturing the SM R232 with the micro USB then changed in mid production to have both micro USB and Type C USB.
