donm527
It's not. It's a hardware issue... either a defect or just outside of tolerances where they are hoping a sw update is going to widen the amount of red they can pull out and bring back in to tolerance. if they can't convince you it's good enough then you're left with exchanging it. It's all about minimizing the amount or returns and exchanges.
Again, I don't understand how it can be a software problem if only some phones have it. All S8 phones run the same software plus or minus the carrier bloat. So it would stand to reason if it were only a software issue all s8 and s8+ phones would have it or not have it. Mine is getting worse so I'm off to Verizon for an exchange.
