1. sfldg's Avatar
    Is mms working out of the box for people? It looks like it isnt working for me. I setup all my apps, and whether its textra or messages plus, i do not see mms.
    04-21-2017 11:30 AM
  2. rossnovak123's Avatar
    Same issue. Anyone else?
    04-21-2017 12:26 PM
  3. sfldg's Avatar
    I just rebooted my phone twice, and activated wifi calling and now its back to normal
    04-21-2017 12:31 PM
  4. rossnovak123's Avatar
    Single reboot worked. should of just did that right away. duh!
    04-21-2017 12:46 PM
  5. gernerttl's Avatar
    Mine is working. I shut off Verizon's message app and used the stock "Messages" app. I texted a couple of videos last night with no worries.
    04-21-2017 12:51 PM
  6. Nubwy's Avatar
    Been working since yesterday.
    04-21-2017 01:18 PM
  7. Kalnel's Avatar
    I'm suddenly getting every text emailed to me. Anyone know how to make that stop? There must be a setting somewhere that it causing it.
    04-21-2017 05:09 PM
  8. gernerttl's Avatar
    Which messaging app are you using?
    04-21-2017 05:30 PM
  9. EngineerGuy's Avatar
    Just came here to see if anyone else was having the MMS over WiFi issue and it looks like I'm not alone. Using Google Messages. I'll try the reboot. Figured that would be too easy of a fix.
    04-21-2017 07:47 PM
  10. EngineerGuy's Avatar
    Yep, it was too easy. Didn't fix the problem.
    04-21-2017 07:50 PM
  11. D0omzone67's Avatar
    Same issue here have tried all of Verizon's steps and still no dice
    04-21-2017 08:26 PM
  12. Kalnel's Avatar
    Solved my problem. I had "sync messages" checked in the email app for my corporate exchange account.
    I'm using Verizon's Messages+, which seems to be working fine. I noticed that the native Messages app is also syncing my texts, but it is not selected as the messaging app.
    gernerttl likes this.
    04-21-2017 08:45 PM
  13. EngineerGuy's Avatar
    Switched to Samsung Messages. That worked.
    Cleared cache, rebooted, switched back to Google Messages, set as default, and now it's working again.
    Whiskey Tango Foxtrot
    04-21-2017 09:15 PM
  1. Why is mms not working when Wi-Fi is off?
    Last Post: 12-16-2017, 08:53 PM
  2. Problems with two languages / Predictive Text on Samsung S7
    Last Post: 12-16-2017, 08:52 PM
  3. HTC One A9 Variant Sytem Version Problem
    By pankajupadhyay05 in forum HTC One A9
    Last Post: 04-21-2017, 01:53 PM
  4. What's causing the ongoing problem with my sound.
    Last Post: 04-21-2017, 01:52 PM
  5. music problem
    Last Post: 04-21-2017, 01:33 PM
